Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: 202
    L67 vt series 2 calais
    Oct 2008
    Default 202
    Hi i'm building a replica group 3 vk with the black 202 but i want to do more with the basic 202 performance wise so can anyone help me out. prices on part would help too and how it would help it im new to this
    this being second post didnt realise i had put in the v6 threads
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Mate 308's are worth sweet FA nowadays, might be better off dropping one in and making your Group 3 Mock up look and sound alot more real.
    If not, i dunno, turbo it?
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    Oct 2008
    sir355's Avatar
    sir355 is offline Father Figure
    VR SENATOR 215, HZ ute
    Sep 2006
    Cairns
    get a good head, some big valves, rollers, cam, and either a 465 holley or even better a set of triple webbers, once you set them, they stay tuned, unlike triple su's, or you could go for the injection that came out on the vk's. 5000 will get you a very stout motor, the 4,6&8 shop can lead you in the right direction, Dave adams is the man in adelaide
    LIVE BY THE SWORD
    DIE BY THE SWORD
    vh wagon/efi 202 off road car
    Apr 2008
    hsvtj's Avatar
    hsvtj is offline now cruising..
    VK wagon, VS Statesman 5.0
    Jul 2005
    Berwick
    i guess with the p plates you cant go forced induction either can you?
    theres some very very quick 202s getting round with s/c and turbos
    Worked VX Calais International
    Oct 2007
    Western Suburbz
    Quote Originally Posted by oOSparkyOo View Post
    id love a 308 but yeah P plates
    aint p platers aloud to drive 5L's
    VS ute
    Nov 2008
    VP SS
    Jan 2008
    Hiding in WA somewhere
    V8 WK Caprice + VK berlina
    Mar 2008
    Blakeview, Adelaide
    81caprice is offline Banned
    VZ clubby-ve ss
    Jan 2009
    Sa its legal
    Jo3_Blo's Avatar
    Jo3_Blo is offline HZ Holden Fanatic
    WB 1 Tonner, VS Ute
    Jun 2006
    Well in vic its not.
    Anyone remember the 300 hp 202 Street machine did in their march 08 issue (i think...maybe 07, can't remember)
    I want one of those ^
    FORSALE - BRICKIES TRESTLES + SOLID STEEL SPIRAL STAIRCASE. -
    http://forums.justcommodores.com.au/...ressively.html
    '82 VH 202 SL/X
    Nov 2008
    Quote Originally Posted by Jo3_Blo View Post
    It wasn't a 300hp one it was a 200hp one. It ran in Jan/Feb 2000 that's the link for it right there
    Jo3_Blo's Avatar
    WB 1 Tonner, VS Ute
    Jun 2006
    Nah. That must've been another one. Coz I wasn't even reading sreat machine back in 2000 lol.
    There's a more recent one. 300hp I'm fairly sure. Although 200 would still be nice......
    Any idea how much it cost to get to that spec?
  15. #15
    vb sle
    Jan 2009
    adelaide
    head port,knife edge crank,starfire rods,solid cam,60" pistons,up the compression it ll go great
  16. #16
    '82 VH 202 SL/X
    Nov 2008
    Honestly? No idea, I haven't been looking at that side of things with the 202.
  17. #17
    Jo3_Blo's Avatar
    WB 1 Tonner, VS Ute
    Jun 2006
    Fair enough. Nor would I be if it wasn't for the P plate laws lol.
    Leigh0705 - DO you know roughly how much it might cost to get all that work done?
  18. #18
    vb sle
    Jan 2009
    adelaide
    crank $around 500 on ebay but im prity sure an engine rebuilder could do this not sure how much rods around$500 port $400 i think cam and lifters probarly $400 balance $200 itll cost a fare bit then you got acl race series gasket kit $500 plus machining double row timing kit $150 probarly a few more that i have forgotten as you can see not cheap
  19. #19
    Jo3_Blo's Avatar
    WB 1 Tonner, VS Ute
    Jun 2006
    Gees, thats probs around 3 grand.
    Well 202s had 86 kw standard, so those mods would probs bring it up to around 150? dunno, just a random guess.
  20. #20
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by leigh 7005 View Post
    lol $500 for stock rods that are the same as blue and black motor? Gotta be a joke.
    Lifter and cam wont cost more than 200. Dont waste time on porting heads either get a yella terra or use a 12 port efi one.
    Balance bottom end is likely to cost $250-$350 depending on your rod crank and piston combo.
    You could get a race series rebuild kit for not much more than $500 maybe $700
    double row timing kit WTF??? they run helical cut gears that mesh together either get a nice aftermarket set of them or go some striaghts if you want a bit of noise. Cost about $100 or less.
    Machining wise your looking at
    $200 for bore and hone
    $90 to deck block
    around $300 plus to line hone crank and cam tunnel
    depending on the head you have and what needs doing can cost up to $500 but you could get a reco stock one for half that price
    throw in the bottem end balance your looking at a total of $1200-$1500 for all the machine work
    another $1000 for all the parts and it $2500 then you either assemble yourself or pay someone to do it.
    Best way to make more power is to build a decent 12 port motor use a yella head and some flat tops run a decent cam and run efi manifold with aftermarket ecu should make 100rwkw or there about with that.
    Stock efi made around the 117kw mark and theres some big gains to made just with an aftermarket ecu
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  21. #21
    Jo3_Blo's Avatar
    WB 1 Tonner, VS Ute
    Jun 2006
    Gees, there's still a fair bit of money involved. $2500 upwards.
    And another thing I have to factor in is that I will be governed by the new P plate laws. But then again the cops won't really be able to tell that my motor is that modified will they? Are the YT heads look exactly the same as the stock ones?
    And another thing, if I get my motor rebuilt I would probs build it so that it can run on GAS or Unleaded or probably both.
    If the time comes, I'll probs just rebuild it to fairly stock specs, maybe a cam or something, I dunno, we'll see when the times comes.
    Thanks for the info Pub!!
  22. #22
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    yella terra look stock beside mainly yellow paint doesnt mean they got to be yellow though you wouldnt be able to tell with out removing manifolds though double valve springs might indicate performance.
    If your going gas or unleaded a dissy regraph will be in order. My last 202 in the vh had that much compression and the original dissy that it was utter rubbish unless i put 98 in it and itd still ping even then.
    Buy an exchange head is the easiest and cheapest way to run gas hardened seats and valves in it so recssion doesnt become an issue
  23. #23
    vb sle
    Jan 2009
    adelaide
  24. #24
    vb sle
    Jan 2009
    adelaide
  25. #25
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    blue black and efi ones have minor differences depending on which model it came from some say efi flow a little better but i doubt they do only main difference is they dont have the air injection ports on exhaust which could improve flow slightly. Hence why i said get an efi one.
    Blue you have two main types with the 173 aka 2.85lt head and the larger 202 aka 3.3lt head. I put a blue 173 head on my VH and rebuilt the yella terra one on it the compression was crazy with flat tops so i suggest not doing that
