Results 1 to 17 of 17
Thread: 202 go fast
    White202 Guest
    Smile 202 go fast
    Hey im new here and i just bought a VC commodore today. Its a stock SL with a 202 and a trimatic.
    Im on a $1000 budget and would like to know the best way to make it go a lot faster (stopping quick is good too). Any replies would be appreciated.
    Dogmeat Guest
    first thing youd want to do is a service with new fluids and filters because that will set the stage for any more serious improvements you want to make to it then you can just go anyway you want with exhaust systems, cams, intake etc hope this has helped in some way
    cheers
    heat1 Guest
    MoSkA's Avatar
    MoSkA is offline Steriotypical Wog
    1998 Subaru WRX
    Jan 2005
    Yeah then for the VL RB30, sell that and buy a VX SS.
    I don't use windscreen wipers, i just use the superior handling of the STI to dodge the rain drops.
    ripfast Guest
    VL Crapbox
    May 2005
    its a blue motor yer - what colour is the motor. Red untill VB i think and then black on VK. If it has a 12 port head then thats really nice, some porting and a cam will go a long way. 12 port heads have from memory separate exhaust manifold pipes where as 9 port heads share exhaust pipes 2 at a time.
    Straight away piss of the varajet carby and put a 350 holley or the likes, it will chew the juice but you'll go like the clappers. The secret being to keep the polution hoses and make it look like they go somewhere cause VCs must keep polution gear.
    Thirdly is a 2 1/4inch exhaust with extractors for about a 10 - 20% power increase. Pick all that stuff up from wreckers and do most of it yourself and you should be sweet. (My VB 5ltr years ago i did the extractors and then drove the bastard 30min to exhaust shop and it was throwing flames)
    If you just do the carby and exhause and buy it all second hand then it should cost you $5-600. Shop around, it always pays to research.
    Vk sl
    Feb 2005
    Brisvegas
    Default which hoses bucket??
    hey bucket i have got 350 holley on a black 202 in a vk a recently *borrowed* off a mate... just wondering wat hoses are the polution ones - where do they run from and to ?? their is 3 holes on the top my motor, i think one is an oil thingy and the one at the back has a thingy coming out of it.. must check where that is going and yer the one in the middle of the block has nothing on it at all... i hav seen other vks with little filters on the top of it?? is this for pollution??
    need sum clues
    Patty
    VY SS II, VT SS II
    Feb 2005
    SE Suburbs Melbourne, Victoria
    Question
    Quote Originally Posted by Bucket
    I recently bought a 2 1/4 sports exhaust for my VC. How much do extractors cost, and will they affect the fuel consumption?
    VL Crapbox
    May 2005
    As for the hoses, you will have polution hoses on post 1976 cars that must be hooked up, usually connected to vacuum parts on the carb down low and they need to be hooked up simply for emissions reasons, its a big fine if the coppers hate you and ask you to pop the bonnet.
    As for the extractors, make some calls mate to wreckers and get some prices, each wrecker is different. Dont buy em new as its double the price and extractors dont wear... As for the fuel, if you put your foot down the power is used 2 ways. The same amount of petrol will give you more power and you will go faster or less petrol (accelerator) will give you the same speed so yes you could save money or no, you will go faster for same money.
    VZ SS
    Jun 2005
    If it's standard a few budget mods
    • Air filter, either drill holes in the base or go the fully exposed element type. If you do drill holes in the base make sure they are on the outside of the element otherwise there will be no more filtered air. A ramflow works well.
    • Exhaust, 2 1/4" or a 2" with a big muffler. We used to use a big single muffler glass pack straight through with a resonator. All steel mufflers work better but will drone a bit. Extractors will help a lot but will cost a few $$. Make sure your EGR is working well or remove it COMPLETLY. If it is sticky it will keep excess heat in the inlet manafold robbing a bit of power.
    • I would keep the Varijet carb as these have 3 stage metering (better econmy, more power) rather than a holley that has 2 stage metering (320,350 or 500)but block up the extra smog ports on it. With extractors it should make it run leaner so you wont need to get it rejetted. Make sure the carby is in good condition though no wear/leaks through the throttle shaft. A manual choke conversion to ensure it isnt closing during WOT.
    • Get a black motor ignition. New plugs and leads if they are faulty. An old trick used to be always give the coil 12 volts.
    It will look stock bar for the extractors. There are a few other mods like diff , reground cam that will go better but will go outside the budget maybe?
    Good Luck
    lxtorrie669 Guest
    Go pick yourself up a cheap Vk EFI from the wreckers thats running will cost you about $500. Remove the EFI running gear and put this on your car. Will be the best mod you can make for you $$$ as the EFI 6 was the best of the straight 6's produced.
    Then sell the rest or keep it for parts
    VK Calais
    Aug 2005
    dont just put the EFI gear on the blue motor put the hole VK EFI engine in as they run a different camshaft and so have more power.
    Hector martinez Guest
    one of the first mods you should do is port the heads for better air flow then a set of extractors and a 'mild' cam (Hydraulic) will get you started
    Jul 2005
    in my "modifying your torana" magazine there is an artical about these blokes in melbourne who can get 280rwhp out of a 186.
    this is a quote from the article "we could extract even more power from it, considerably more, but that would make it a pure race engine and that would be a pig on the street"
    so as you can see the little 6's when worked correctly can perform very well.
    when i plug my scanner in ill scan teh article so you can all read it. its a great read and has a few pics too..
  15. #15
    MY08.5 SV6
    Aug 2005
    Loganholme, QLD
    Thumbs up Easy L6 Power
    Im only a young bloke but the three C's [B]Cam,Carby,Compression.
    A decent exaust system wont hurt ether.
  16. #16
    97 vs statesman v6
    Aug 2005
    bendigo
    have you changed you rocker cover at all, how many holes has it got in the rocker cover...
  17. #17
    That's true if you dont have much compression you'll have a lazy engine
  1. how fast is your vl???
    By Sabby in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-03-2007, 07:09 PM
  2. help me go fast!
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 02:10 PM
  3. Need Help Fast
    By Burnout_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2007, 06:30 PM
  4. How fast?
    By vsII manual in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2005, 12:27 PM
