Results 1 to 4 of 4
Thread: cam gear timing RB30 Turbo
    VL Turbo
    Mar 2009
    Default cam gear timing RB30 Turbo
    Gidday guys , just signed up .looking for help with cam gear timing on Rb30 turbo. I bought a wrecked VL Turbo and transplanted the whole drivetrain into my Berlina,all has gone well. Last week fitted new TO4E ,and blew the head gasket with aboost spike,changed the head gasket ,set cam gear to standard marks and started it up ,runs well. took it out for atest and it seems to have lost or moved its boost rpm up about 600 ,it used to boost 3000 now its easy 3600 . Apparentely the motor did produce good horsepower before the car was wrecked 220rwkw so it may run a cam,if thats the case .atooth forward might be the go ,anyway can anyone give me any advice . cheers mick
    VR Manual Wagon
    Mar 2009
    Hi Mikkcee
    I can't help you with your timing, but you may be able to help me with my problem.
    I am after the complete EFI & ECU from your old VL motor. If you still have it message me and we may be able to come to some arrangement.
    Kev C
    VL Turbo
    Mar 2009
    Default Advance and Retard cam timing
    Quote Originally Posted by mikkcee View Post
    In repley to my own question this is what i have found on other forums . Cam timing plays a very important part of when your motor develops boost,advancing by 6 degrees or one tooth 54 teeth not 53 dropped my boost rpm back to 3000 where it must have been originaly set.Retarding sends boost time further up the rpm range,this apperantley is used to get high rpm without busting stuff for better launches . this above procedure has been done and it works .cheers mick
    VL Turbo
    Mar 2009
    Default Kevs VL Stuff
    Quote Originally Posted by Kev C View Post
    Hi Mikkcee
    Kev C
    Gidday Kev ,cant help with ECU but we have 3 NA motors what exactly do you need ,by the way we are north of cairns FNQ freight might be a issue
    Mick
  1. V6 Hellical Timing Gear Drives 4 3.8 V6 Where?????
    By mad13b in forum V6 Development And Modification
    Last Post: 03-02-2007, 12:26 PM
  2. rb30 to turbo
    By deccers in forum Straight 6 Development And Modification
    Last Post: 07-11-2006, 07:40 PM
  3. rb30 to turbo
    By deccers in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-07-2006, 06:52 PM
  4. vk 3.3 efi to rb30 turbo
    By sandman_538 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-06-2005, 09:01 PM
