Results 1 to 3 of 3
Thread: COOLING FAN - ICE brand, dead - part needed
    v6lux is offline
    VN S1 (was VR) V6 Hilux
    Apr 2009
    Default COOLING FAN - ICE brand, dead - part needed
    DESCRIPTION: Swap/ Wanted to Buy / Trade
    ITEM: Dead ICE cooling fan motor brush and spring
    LOCATION: Western and Central Sydney region, this month
    CONDITION: New or Used?
    DELIVERY/PICK UP INFORMATION: Will pay postage or local pick up.
    PAYMENT OPTIONS: Peanuts or Cash or Beer
    CONTACT DETAILS: jcw01@optusnet.com.au
    OTHER INFO: If you have one of these ICE branded fans not working, let me know
    In the picture you can see the brush on the right has the wire melted off and the spring also melted. The brush on top right is the way it should be.
    Apr 2009
    I forgot to mention, these fan motors are really, really easy to take apart, however, they are a real bastard to put back together. The 4 brushes in the the ass of the motor are hard to hold back to insert the commutator thingo. Do don't pull apart a good one, unless you want dramas.
    The wiring inside is for 2 teminals so I wood like the complete 2 brush and wire with terminals if possible, but if only one is OK with terminal and at least 1 inch of wire, that should be OK and 1 good spring.
    Apr 2009
    Well! I got no replies, but had time and did fix it.
    Low on cash, so I went to a self-serve wrecker and found the broken fan pile. Pulled apart 5 or 6 fan motors till I found a good spring and a Brush big enough to file down to the correct shape and size. Also found one of the bearings was stuffed. Most fans have the identical type bearing, so that was fixed too.
    While I was at it, I gave the Commutator Bars a bit of a hone with w&D. Putting it back together is a real tricky task. Had to bend nails to make hooks to hold the Brushes in so I could insert the Armature into the housing. I put the magnet in the opposite way, so I had to reverse the wire polarity to fix that after install into car.
    Works great now.
    If anyone has a broken one, I'm still chasing for a spare motor!
    Thanks
    Attached Thumbnails Attached Thumbnails COOLING FAN - ICE brand, dead - part needed-p1030371-small-.jpg   COOLING FAN - ICE brand, dead - part needed-p1030375-small-.jpg   COOLING FAN - ICE brand, dead - part needed-p1030379-small-.jpg
  1. Part Needed . Help!
    By MICKY B in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-01-2010, 04:49 PM
  2. URGENT! what is this part called? re: cooling system
    By ryanst8o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2009, 09:19 PM
  3. [SA] FS : Pc Part - ATI radeon 4850, brand new
    By acex1138 in forum Parts And Other Items For Sale
    Last Post: 23-10-2009, 05:45 PM
  4. Vx v6 Engine part, who can name this part?
    By Hot-Rod in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-03-2009, 04:09 PM
