DESCRIPTION: Wanted to Buy
ITEM:
1. VS v6 Auto floor shifter assembly (including plate and whatever links onto that long rod off the side of the trans) that also all the parts that fit in the console like support link, slider, positions scale etc.
2. The PWR/Eco button that fits in the VS Statesman just under the shifter.
3. VS V6 Statesman BCM (not sure if this is just a Hi-BCM or Lux-BCM) with remote head. Also think I need the ECU to make this work too and possibly the wiring.
CONDITION: New/Used
DELIVERY/PICK UP INFORMATION: Prefer pickup arpound Melbourne.
PAYMENT OPTIONS: Pay cash on pick up
CONTACT DETAILS: PM me
OTHER INFO: Would like to get the auto shifter gear before next weekend so I can get my column shift to floor shifter install happening.
Cheers,
Luke.
Hey mate i've done this conversion, the column shift trans tunnel is actually different, its flatter to accommodate the bench seat. I had to chop the top out of a sedan tunnel and weld it in.
Hope that helps.
Do not listen to anything this man says, they are insane illogical thoughts propagated by us, the voices in his head.
This stato gear is going into a VS V6 Ute. Why did you have to cut the top of the tunnel, did you convert a column shift into a sedan? The autos them selves are identicle except for a longer selector shaft on column shifts auto (7CHD) as opposed to the T-bar one that I have (6HDD), unless there is something else other than the trans itself?
PM replied to.
Thanks for all the PMs on parts guys. Looks like I have what I need, so if this falls through come Saturday, i'll be getting back in touch.
Now just chasing the Floor shifter (with switch/plate) and the black slider only. Must be in good condition.
PM me with anything, sooner the better
pm sent for your floor shifter you are chasing
