Looking for a VS L67 engine loom, also a VS ecu...
Aswell as a VS V6 automatic transmission..
Looking for parts reasonably cheap...
MaT
Originally Posted by garth
are you after a ecotec or L67 pcm?
vs ecotec and l67 computers should be the same. i can burn hozy a l67 xu6 tune on an ecotec chip for him.
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
ive heard the vs had various components missing depending on their application. ie. auto manal and l67 will slightly be different. From memory the only extra wiring the L67 has is boost solenoid and the pump controller. If you dont need those then i cant see why an ecotec wouldnt work.
hosy, Ive got a spare vs ecotec pcm, which you can have for $20 + post (has no memcal though)
Hozy, why not use your existing VN loom & ECU and keep it MAFless?? Get your existing auto rebuilt with some good gear in it and use that aswell.....
Hmm didn't think of that.. I just wanted to go sorta legit factory based setup..
But that can work... Only thing, i needa know, whats different on l67 loom to the standard loom...
THREAD CAN BE CLOSED!!!!!!!!!
I got a VS engien wiring loom and Auto ECU.
Also wreaking a white VS, most parts there still.
Ley me know mate
