Thanks for the quick reply. The fridge is rated at 75 watts so I'm guessing that the female cigarette connector should be OK. Thought that I might tuck it away behind the cover for the 7 pin trailer plug. Any thoughts about where I should take the power from?
take from direct from your battery, I included a diagram of how i'd suggest to wire it using a relay and a switch to isolate it when you want to turn it off. If you know how to wire relays you should be fine, just make sure the wire is the correct guage etc.
No offense, but that diagram was a recipe for a fire in a couple of years. Here is the same diagram but modified. A fuse has been added shortly after leaving the battery. Don't run another wire from the battery to pin 86. Just "tee" it off the connector for pin 30.
