2004 SV6 - 'Check Powertrain' caution
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by gam, Jan 28, 2006.
  1. gam
    gam New Member
    SV6
    Howdy all. Was just driving my 2004 Holden SV6, and the 'Check Powertrain' caption came on :my: . Book says "it indicates an emission control fault. Although the vehicle may still be driveable, reduce speed blah blah blah, and get it checked by Holden".
    Can't get it looked at until Monday (Today is Saturday).
    Has anyone elso had this, does anyone know what it means, and if it is hard / time consuming on their part to fix????
    Any Clues - please pass em on. :confused:
    cheers
    Gam
  2. benzor
    benzor yawn :(
    SV6!
    Happened when i pulled my MAF out :)
    Could be anything
    Engine
    o2's
    MAF
    Throttle Body.
  3. GroopA
    GroopA New Member
    Perth, SOR
    '05 Impulse VZ SV6
    Had it happen to me too.
    Was just a faulty O2 sensor which got replaced under warranty.
    Didn't harm the car at all, just ran a little bit richer.
  4. nightmare
    nightmare New Member
    VZ SV6
  5. Doctor Bob
    Doctor Bob Grandpa
    Mornington Peninsula
    VT V6 Exec & VN V6 Exec
    The check powertrain warning is nothing to do with the software issue, it indicates a fault with the engine management system & should be checked by a dealer asap.
    Rob
  6. HOTSV.6
    HOTSV.6 Guest
    Happened to me a couple of months ago. Turned out to be a faulty left bank O2 sensor that was replaced under warranty.
  7. jaisvz
    jaisvz New Member
    Black VZ SV6
    On my way home from work last night about 10 mins into my drive home... my car started beeping like crazy and "CHECK POWERTRAIN" caution came on... i see other people have had this and it turns out to be a faulty o2 sensor? I shall ring holden and get them to have i look. My sv6 has only done 22,000k's and i don't thrash it, mainly all highway driving... so i hardly think there would be something majorly wrong!
  8. Doctor Bob
    Doctor Bob Grandpa
    it means there is a fault with the cars engine management system & it needs to be checked.
    as described in the owners handbook...
    Rob
  9. jaisvz
    jaisvz New Member
    Black VZ SV6
    Faulty 02 sensor....
  10. VZSV6
    VZSV6 Guest
    unplug the sensor disconnect the negative terminal for 10min replace the sensor back then reconnect the terminal..fixed
  11. Doctor Bob
    Doctor Bob Grandpa
    the car is under warranty dont go unplugging things if you dont understand, take it to get it fixed by someone who knows what they are doing.
  12. jaisvz
    jaisvz New Member
    Black VZ SV6
    Um, its already replaced. ;)
  13. JanetSSV
    JanetSSV New Member
    Mandurah W.A.
    VE SSV Ignition
    Mine's just come up with the same warning. Rang Holden and advised not to drive if possible. Have another option so that's ok for now. Has anyone else had their car in for this warning and if so what was the problem causing it?
  14. JanetSSV
    JanetSSV New Member
    Mandurah W.A.
    VE SSV Ignition
    Had mine in today and was told it was only a software issue which has been updated. Will be interesting to see what happens.
  15. JanetSSV
    JanetSSV New Member
    Mandurah W.A.
    VE SSV Ignition
    Got the same warning come on again Wed. morning. Took her back in again in the arvo. Ran a scan told it may be software or a wiring problem. Still safe to drive. Can't get her back in until Monday (partly due to my schedule with tafe) Then they have to do more tests. Good now I've got no car for my 1 day off. yay fun
  16. JanetSSV
    JanetSSV New Member
    Mandurah W.A.
    VE SSV Ignition
    Took her up to Freo today (about 150 km round trip) she's running really rich. used nearly half a tank normal would be about 1/4 . per 100km started at 14 for around town by the time we got home was on 12.2. that's really bad. bet they dont give a rats ass about the fuel I've wasted when they told me she was ok to run and they knew where I had to go this weekend. Damn them. would have taken the VL out for the run but the fuel pumps are on the way in her atm. Had to get her towed home on Monday arvo. No win situation atm.
  17. JanetSSV
    JanetSSV New Member
    Mandurah W.A.
    VE SSV Ignition
    O2 sensor replaced. hope all else is gonna be good too now
  18. sv6_driva
    sv6_driva New Member
    04 VZ 3.6 SV6 Commodore
    Oxygen Sensor
    My Oxygen sensor (left side of block) **** itself at about 25k and gave this warning on dash. Replaced under warranty and fine now. Seems like a very common problem!
  19. Kersh
    Kersh New Member
    Woonga, VIC
    VE SS Ute '08
    I had the same prob with my 06 VZ the other day, its only done 23000 km. Tech2 readout said 4 oxygen sensors were stuffed, they are all fine tho, just needs a software update.
  20. itsonlyme
    itsonlyme New Member
    VZ SV6
    yeah happened to my parents got it replaced within a day under warranty then it came on again so took it back and it has come on again since
