Air Conditioning Advice
kkeivm
VR Berlina
hey my aircon stays on even when i turn the car off any solution
nobullneeded
Western Australia / SOR
06 SVZ
First of all, I think this question may have been answered some where in the last nine page. Unfortunatley, Im having trouble finding it.
Have a VR V6. Aircon works brilliantly. Apart from the fact that you can not change the direction of the flow. (Turn top nob. It remains on floor vents). Have tried a replacement module, Didnt fix the problem.
It also seems there maybe a short some where in the system as it keeps blowing out fuses. Any ideas where to start?
VS_Pete
Donating Member
keithh
G'day all, have been reading thread looking for an answer, still am unsure?
My VT 98 has the following issue:
Air con light comes on when pressed no worries,
Compressor will not engage,
The only fuse/relay I could find labelled aircon was under bonnet near battery.
A mechanic mate checked & even with switch pressed on, there is no power getting to the compressor.
What fuses (if any) are under the steering colum that I could look at, or am I missing a location of a dedicated fuse for the aircon?
Any help would be greatly appreciated. Cheers
M01ST
15 VF SSV Redline, 02 VU SS Ute
Sorry there are so many pages cbf reading them all...
My aircon/heater/fan wont work on 1/2/3 setting but it will only work on 4???
Cheers for any advice
jokerflingo
Holden VY SS 2003 - 6 Speed Manual
Are there two separate fuses for 1/2/3 and hi mode?
jokerflingo
No idea was thinking more of a bust switch maybe just asking other opinions.
Yer probably more likely scenario, which sorta sucks for you, probably a trip to the wreckers to grab another one and get stuck into your console. Id check the fuses first :whistling
M01ST
Mmm like you said is there seperate fuses for each one or not.
jokerflingo
Thats what i was questioning you about :p i always thought that the high mode fan also operated the rear demister on the same fuse. Unsure about 1/2/3 but i believe they would be the same fuse and operate something else as well.
