digisol
- Oct 6, 2005
- 537
- 5
- 0
- Location
- Central QLD
- Toyota Landcruiser
How about a problem where the a/c works fine one day but simply does zip the next day, dash seems to be OK, no blown fuses that I can find, the dash fan works OK.
The compressor just no longer kicks in.
Not that it should matter but the compressor pulley bearing ($50) was replaced a month prior but nothing else was touched, literally, and the a/c worked fine both before and after, but without the noisy bearing sounds.
I have been told by fairly relyable source that once the gas drops to a certain pressure level the entire thing just stops which is what happened, is this true.
The thermo fan also does not kick in, allthough it might if the thing was hot, I have not tried to boil it just to check the fan.
