Chaney
Thought I'd sign in and do an update from my perspective and noticed a few replies etc, but where I am at now is:
Holden have no tensioners left in Australia basically, the left hand side (passenger side) is due into Melbourne on 23/03/11, and the right side is not due into Melb until 29/03/11. I was able to get the passenger side and primary tensioner before they went out of stock, but right now my car is garaged until I can get the right side. According to Eagers holden there is a back order of about 250+ tensioners across Australia which means 250+ VE's off the road until this part arrives in Australia. Apparently the tensioners are failing in hordes so anyone doing a change I recommend installing the revised parts (all 3 tensioners). I have replaced all chains, tensioners and guides to be safe.
Right now my car is my garage all timed up, but no RHS tensioner means I cant put the rest together until I get it. Worst thing is I can tell my VE has been opened up before (dodgy ie not factory bolts etc used, and BTW has only ever been serviced by holden through lease plan, before I purchased it). Seems like the timing chain was replaced before but now the tensioners have failed and my primary chain had slipped one tooth, no wonder it wouldn't start.
Thanks Vt for the info, I wish I would have had that info earlier but I have fumbled my way through the process (actually the service manual helped alot). I would probably leave the rocker cover gaskets out tho as the seem reusable and at approx $100 each is ridiculous. Unless there is a reason for replacing them?
Special tools need are the flywheel locking tool, power steering pulley puller and probably the pins to guide the front cover back on (i haven't got there yet but do have these)
The camshaft locking tool is definitely not needed as mentioned by Vt, I just rotated the engine by hand until it was all lined up, then took off chains and replaced without any problems.
Feel free to ask any other Q's also, for anyone else out there doing this job which shouldn't need doing.
Chaney.
Chaney.
