Alternator Warning ?? VE Alloytec
Discussion in 'VE Holden Commodore (2006 - 2013)' started by greenacc, Dec 16, 2012.
  1. greenacc
    greenacc Searching for the billion
    VE Berlina
    So i went for a drive today and just as i pulled into a carpark the Alternator warning popped up on the centre screen. It came up again after shopping then disappeared.
    It's the first time i have seen this warning and i've had the car over 2 years. It's got 180,000 k's on it.
    Did a search and found an old thread about a rusty terminal so i will check that out. Has anyone here had to replace their Alternator on a VE Alloytec ? I see Holmart has them for about $290 if i need to go that way... would i need the 100 or 120 Amp unit ? It is a series 1 Berlina.
  2. greenacc
    VE Berlina
    Hasn't anyone had this issue before ?
    I checked what i can see of my alternator and it is a 100 Amp unit and i can't see any corrosion on anything, but its hidden away pretty well se i can't see much.
  3. Sean880
    Sean880 Member
    VIC / NSW
    2012 VE SV6 series 2 and 911 Porsche 997
    With those 180000 kms and operating hours on the car the brushes in the alternator will be badly worn and need replacing. They are a wear item and do not last indefinitely. At the same time change the voltage regulator . Or you can renew the entire alternator.
  4. Benboy
    Benboy Active Member
    Hill River, SA
    2007 SVZ Wagon
    Take the car to an Auto Electrician to have the problem diagnosed. To do otherwise could be a complete waste of your money as it seems you do not have a very high understanding of automotive electronics. Good luck.
