Jxfwsf
The car drives better (which isn't hard as the front shocks removed were the originals from 88)
Well it's a work in progress, I'm not happy with the steering/handling.... after an alignment it's very doughy and slow to react turning (at least it doesn't tramline on the freeway like it used to, same tires and springs as before), seems to have reduced the turning circle... which is a bugger for doing Ubolts.
Need to do something about the camber... -3°30' and that's the most i could get out of it (at least it's even left and right, guess i cut those top plates pretty damn close to each other)
Caster could be a problem..... just doesn't self center to my liking, tracks straight when the wheel is let go so there's a bonus.
Rob, currently the rear brakes are just the std VN discs, the fronts do most of the work anyway but I will be looking into putting the VT rear caliper and rotor's on but at a later date (It can be done and there are adapters out there already but I'm more the type to see if i can manufacture this sort of thing myself)
Crunching the numbers:
A: Distance between shocker shaft:
B: Distance between shock shafts and firewall
C: Distance between shock shaft and lip on guard
VR/VS:
A: 110cm
B: 22.5cm
C: 18.5
VN with this hybrid setup:
A: 103.5cm
B: 27cm
C: 21.5
From underneath... the distance between the center off the ball joint to the tie rod mount on the steering knuckle is 1.5cm longer on the VT... Will chase up some VR/VS parts to replace this, assuming they changed some other angles here also so may not need the VT rackend/tierods (If the hub/bearing assembly can be interchanged) this should make a difference to the slack steering response and liven it up a bit (all other important measurements were the same.
VR/VS:
A: 110cm
B: 22.5cm
C: 18.5
A: 103.5cm
B: 27cm
C: 21.5
