Braided clutch line
NU13
50
New Zealand
2007 E1 HSV GTS Manual
Well finally got my braided clutch line in for VE GTS. While the new line has not totally fixed the issue it is about 70% better than it was. Or in other words the clutch pedal now only losses about 2 cm worth of pressure not the 7 or 8 cm's it previously losses.
So i guess the complete fix is a new after market clutch or the LS7 clutch.
vr304
Auckland, New Zealand
2007 ssv manual
Are you loosing pressure after giving it a good flogging? Or just regular driving? I have this in my VE ss it's usually just after a good hammering
NU13
50
New Zealand
Yep thats the one. Sprinted driving causing the issue when you are running after market extrators. Stock units don't produce the same heat.
Towcar
Auckland NZ
VX Berlina Wagon
so are you boiling the fluid? Have you tried silicon fluid or higher boiling point to help?
vr304
2007 ssv manual
Where did you get your braided clutch line from mate and how much?
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
will still do it with stock exhaust, and spirited driving, the main culprit in all this is the concentric slave cylinder
NU13
50
New Zealand
Brought it off my tuner who brought from an outfit in Sydney (I'm in NZ). If you take a standard clutch line to a brake or hydrolic specialist they should be able to make you on.
