Bypass immobiliser without key??
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Bungle, Jan 13, 2007.
  1. Bungle
    Bungle Bungle
    VP Exec S2, VZ Exec
    Does anyone know how I can turn my immobiliser off without the key ?? It never came with one when I bought it.. I know i'll probably have to end up going to a locksmith or Holden for a new key, just wanted to check if I could do something myself first...
    Cheers..
  2. cruzncommo
    cruzncommo Banned
    QLD
    VP 5spd
    open passenger side door and on the chassis bit is a little switch thingo for the immobiliser so you can turn it on/off.
  3. Bungle
    Bungle Bungle
    VP Exec S2, VZ Exec
    Yeah I know that, but Im missing the key...
  4. pow3rslave
    pow3rslave DoNothing Member
    eastern subs, vic
    VP 5.0L
    i suppose you could try to get the keyhole out, and just cross the wires it connects to. though i'd hope there's more to it than that.
  5. andynogo
    andynogo New Member
    Wild West
    VP Berlina V8 wagon
    I know it might sound really dumb, but try any key. Mine turns with any old key! Got rid of the factory immobiliser anyway as it was playing up.
  6. MyVPIsFasterThanYourVP
    MyVPIsFasterThanYourVP New Member
    Kingston
    VP Executive S2 3.8L
    if you want to drill out the cover plate, it is reasonably simple to get to the back of the override switch. There are threads here that talk about this in detail, and unfortunately, it is rather easy to bypass the immobilizer this way. (especially if you have two switches, one switched to 'on', and the other switched to 'off') I'm going to get a key cut eventually now that i have one switch removed from the car! Good luck.
  7. fazz1977
    fazz1977 myspace.com/fazz_himself
    Frankghanistan, Melbourne, VIC
    1992 VP Executive Wagon, L27 V6 3800
    Seriously, I'd just get the key cut. Cost me $30 bucks or something (before the $110 for the remote), that way you have options.
  8. MyVPIsFasterThanYourVP
    Kingston
    do you reckon they show the rivets pics of angelina jolie at the factory to make them hardened?
  9. fazz1977
    LOL
    Nice.
  10. V8 Berlina
    V8 Berlina New Member
    SA - North
    VP Berlina V8 / Toyota Hiace
    easy to by pass if you know how to. Its pretty hard to explain.
    If your really keen i can tell you how.
  11. dazzanz
    dazzanz New Member
    vx ss
    all you gotta do is join the pink wire at the ecu to an ignition supply that will do the trick
  12. COMMOKING
    COMMOKING New Member
    VR commo Wagon
    turn key on and wait 45 mins this over rides immobiliser just need a handy 45 mins spare before u leave to go driving may as well polish ur bundle of joy easy but annoying? hope this may help
  13. pidgeon
    pidgeon New Member
    vn
    I have a toyota lexcen and the immobiliser will not turn off anymore and I don't have the key for it. I have tried the 45minute way and it doesn't seem to work. Does anyone know of a simple way to turn off the immobiliser? if not some instructions for the hard way..
  14. rob drag racer
    rob drag racer vn vp drag nut
    golden beach
    vp 3.8 with gas new project vn s1 guted strip only
    thats what i did for my drag vp no need for the s1 vn thankfully :) :thumbsup:
  15. Jayme
    Jayme New Member
    Woodburn, NSW
    VL 5L inj
    yeah its quite easy, theres 4 wires that go to the key, two wires join when the immobiliser is ON to make the dash light flash, the other two join when its OFF to make the car go.
    you will have fun drilling out all the rivets to get at the ecu and wiring though.
  16. josh_scott_1987
    josh_scott_1987 New Member
    vn ss 355, vl, vr, vs ss
    i need2 do this but how
  17. bj42turbo
    bj42turbo New Member
    1990 VN Executive
    Agreed but I am probaly biassed :idea3:
    Dazz
  18. justice4all3000
    justice4all3000 Member
    VZ Calais 5.7
  19. josh_scott_1987
    can u tell me what 2?
  20. Kayden-Leigh19
    Kayden-Leigh19 New Member
    Papakura
    Commodore Executive
    Me too please I'm buying a car off of Trademe ( NZ ) and the fullah I brought it off lost the main keys with the chip or rather on it and I need to figure out a way to get it from Tokoroa ( NZ ) to Auckland ( NZ ) getting it towed isn't a option so if I can get it started with out the Immobiliser then it will be okay till I get the Body Control box I ordered for it...
