Catch Cans
Discussion in 'LSx Development and Modification' started by Munz, Mar 26, 2011.
  1. Munz
    Munz Right Foot Action
    Brisbane NTH
    VZ Calais LS1 / VL RB30e daily
    Hey Guys
    Just wondering why I'm seeing alot of NA guys running catch cans - I understand about being needed for boost but why are they needed on an NA LS1 car?
    N E info would be great
  2. WogBoyz
    WogBoyz 435rkw/590rwhp
    Cairns, Qld
    08 VE SSV M6 Ute
    Have a read of this Corvette PCV Oil Catch Can
    Basically, the Lsx engines have a bad pvc system, and coat everything in the manifold in oil (can be a fair amount, ive seen one lad with puddles of oil in his) so putting the can on stops all that crap hot oily air mixing with the fresh cool clean air comming in and obviously keeps the manifold clean
    I deff noticed mine ran smoother and responsed better when putting it on my ve, after a week or so of driving ive got a teaspoon or 2 of oil in there
    Hope this helps :)
  3. GM GEN3
    GM GEN3 GM GEN3
    S.A
    legs ATM
    I would be keen on a catch can where can you pick them uP from plus i plan on taking my car on the track one day i think you need one or you cant get out on track!
  4. cpbait
    cpbait New Member
    vy ss commodore 5.7ltr
    You can get some good ones on ebay, have a look there, Elite Engineering catch can's look to be the goods from what iv heard.
  5. WogBoyz
    Cairns, Qld
    08 VE SSV M6 Ute
    Yeah ive got an Elite one, very good quality and havnt had any problems with it
  6. SAMO-87
    SAMO-87 New Member
    S.E Melb
    02' VX Berlina 5.7L
    +2 for elite. Excellent product, no dramas at all. I pick up a couple of teaspoons of oil after a week or so of driving.
    Definatley worth the money!
  7. WogBoyz
    Cairns, Qld
    08 VE SSV M6 Ute
    Yeah same, works very well
  8. rb26dett
    rb26dett New Member
    VT SS S2 A4
    +3 Elite on mine also.
  9. VX SS 340 HP
    VX SS 340 HP New Member
    Chinchilla Qld
    VX SS LS1
    I am also keen to install one on my VX SS just a quick question should i buy one with a breather or one with out...and how hard are they to install
  10. macca33
    macca33 New Member
    The 'gul, Vic.
    VX Senator 300
    Another vote for Elite cans - they are the duck's guts.
    I'd buy one that is sealed - as the breather type ones do not comply with EPA rules and you may get pinched if you get pulled up.
    cheers
  11. walesy
    walesy Aint no family cruiser!!!
    Perth SOR
    Cherry Black WH II Caprice, VS exec wagon
    hmm might try one out, did you guys pull your manifolds off to clean them out when you put the catch can in or did you just put it in?
  12. WogBoyz
    Cairns, Qld
    08 VE SSV M6 Ute
    I just wiped in as far as i could to clean the manifold, however mine was pretty much spotless anyway, i wiped the tb down the same way, was also pretty clean
  13. GM GEN3
    GM GEN3 GM GEN3
    S.A
    legs ATM
    Yeah I'm going to get one does any one have a picture of how it hooks up on to the ls1 motor i looked at some pic and a lot of them are different thanks
  14. Ss666
    Ss666 New Member
    Chirnside park vic
    VT SS Ls1
    How hard are these to put in??? What benefits would come from a catch can? How much would a shop generally charge to put one in??
  15. WogBoyz
    Cairns, Qld
    08 VE SSV M6 Ute
    Heaps easy to put on, benifits = clean manifold and smoother running/responsive (read link at top of page) as for the ls1 setup someone on here will prob have one fitted so im sure they can help you out
  16. Darren_L
    Darren_L Active Member
    Toowoomba, Qld
    VH SS
    I realise my engine isn't an LS engine.
    But I found out on my first track day, that when I started the engine, after sitting in the pits following a track session, the engine would blow a heap of oil smoke out the exhaust for 20 seconds or so. Seems it had dragged a heap of oil into the intake. So before next track day I fitted up a catch can and there was no further oil burning problems. And it caught quite a bit of oil in the can, especially in the early couple of sessions where I was had it sitting above 6000rpm fairly regularly.
    Some advice I will offer you from my experience, is a lot of so called catch cans are simply an empty oil can with a couple of pipe fittings. They won't do a proper job of seperating the oil, because there is nothing inside to catch the oil. A proper catch can/oil seperator will have some sort of baffling inside to catch the oil before it gets sucked back into the engine. I ended up buying a catch can with nothing inside (because I couldn't find a proper one), pulled it apart, fit a piece of aluminium plate (with several holes drilled in it to allow airflow) inside dividing it into 2 halves (inlet side and outlet). Then stuffed some stainless steel wool into the inlet side so it would catch the oil. Worked a treat.
  17. WogBoyz
    Cairns, Qld
    08 VE SSV M6 Ute
    Yep what he said ^ the elite however is very good qualtiy and has heaps of that steel wool looking stuff in the top part
  18. GM GEN3
    GM GEN3 GM GEN3
    S.A
    legs ATM
    catch can install
    is this how it goes i found this pic
  19. DLFHUB666
    DLFHUB666 GIT 'EERRR DONE!!!
    Nhulunbuy NT
    VX SS, PX Ford Ranger XLS Dual cab
    ^^^ that is a vy on setup vt/vx LS1 have a different setup. Just thought i would let people know.
  20. GM GEN3
    GM GEN3 GM GEN3
    S.A
    legs ATM
    Does any one have a pic of the vx ls1 set up cos i couldn't find much
