Central Locking Key Repair - Pre-VS
Discussion in 'Holden Commodore How-To's' started by Harts_94VR, May 4, 2005.
  1. Harts_94VR
    Harts_94VR New Member
    94 VR II
    I have noticed quite a few people have had the same problem as me with their remote key. So I put this together with some photographs of how I repaired my key and saved myself about $100 for a new key. Can be done in under an hour.
    THIS WILL ONLY WORK ON PRE-VS COMMODORES! (VR and earlier)
    All VS and onwards keys (and also replacement keys) have a sealed unit that will wipe the internal memory of the key if it is opened up. Anything ORIGINAL from VR or before will be fine.
    shaggerz likes this.
  2. manvr
    manvr New Member
    VN 3.8i 5sp
    hey bro just found this thread, very helpful, i just need to get a mini screw driver
    hey how come you didnt mention that that battery could be flat, or would that take ages and ages to happen?
    cheeers again.
  3. VTW@G0n
    VTW@G0n New Member
    Mid North Coast
    VT WAGON 3.8L N/A
    Gday
    Y does everyone keep saying that post VR keys once opened will wipe the memory? that is bull**** because read my thread in the how to's because i repaired my key for a vt 99, the only wy to wipe the memory would be to remove the battery, there is no circuit attached to the plastic casing that would cause it to lose its memory.
    My key works as it always did, only with a repaired button now :D
  4. Harts_94VR
    94 VR II
    Well, as far as the wiping memory thing, I was only passing on what the Holden guy had told me at the time. I assumed he would have known what he was talking about... but I don't own a VS or anything after that, and I have not repaired the key for one, so I have absoultely no experience in repairing them, and I have no intention of making out that I do. I simply thought that I wouldn't want to be responsible for anyone stuffing up their key and putting themsleves through a bunch of inconvenience.
    So anyway, go easy troops, don't shoot the messenger. :bop:
    I was just passing on what someone who should know more about these cars than me had told me. In the light of other people's experiences, it would seem that the Holden guy may have been wrong, and some people have pulled them apart without any issues. Forgive me for being cautious in that regard.
    As for the issue of the battery itself being flat, my battery was actually ok, but I decided to replace it anyway, considering that it was like $4 for a new battery, and I didn't want to have to rip the key apart again in a few months if it died, so I replaced it while I did the repair.
    Still working fine a few years later :)
  5. JoeCamel
    JoeCamel Guest
    I called Holden too, regarding replacement batteries for my '96 VS key.. They told me that I had to take the key and the CAR to holden for re-programming... WELL...
    When i brought my car, for some STRANGE reason, it came with FIVE spare keys :)
    I did what any normal person would have done and played with one of them..
    I REMOVED the battery. Just to make the point, i left it out for TWO DAYS.
    I went to the store and got the same model battery, de-soldered the flat one and re-soldered the new one in place.. all this was then held back in place with 2 part epoxy..
    so i go out the front, try my newly repaired key and whaddaya know... IT WORKS.
    So in my own experience, what Holden are telling us about keys is utter shite.
    Oh.. I should mention this too: when I had the battery out of that key, i grabbed the key itself (the one that screws into the black button housing) and drove my car about 25kms.. Now, what was Holden saying about the immobilisers?? with just the key in the ignition there is no contact on those two metal whatsits near the keyhole, so the imobiliser should not turn off --> (effectivly the key is a very niclely shaped screwdriver, as there is no contact for the deactivation of the immobilser)
    so much for immobilisers on the VS...
    From what I have seen and played with, Holden VS's do not have any security when it comes to keys... Go ahead, change that battery :)
  6. Harts_94VR
    94 VR II
    Nice bit of investigative work there mate :)
    I would have thought that the immobiliser is switched off when you first unlock the car though?
    But yeah that thingy on the steering column is supposed to be a "key reader." Maybe those contacts are what's used to program the key to the car in the first place.
  7. JoeCamel
    JoeCamel Guest
    could be..... maybe i am a skeptic tho, coz i'm thinking that there isnt a key reader system at all... just a bunch of bells, whistles, smoke and mirrors... but as i say.. i'm probably just a skeptic
  8. mor11J
    mor11J Guest
    I actually thought the contacts were only to charge the battery in the remote? I didn't think there was any "key reader" involved whatsoever.
  9. MaXiLeeCH
    MaXiLeeCH irc.WorldIRC.org boss
    1995 VR Series II Berlina
    Mate, you are a life saver!
    Ive had a dud key here for ages, now all is well with it again.
    Thanks alot.
  10. simmo 76
    simmo 76 New Member
    Koondoola
    V6 VS ACCLAIM
  11. CDMA0428
    CDMA0428 Guest
    If you leave a key in the ignition with the ignition switched on for 1hr and 30 min, you can then start the car and drive it home ( it's in limp home mode). it doesn't work the second time within 30 hrs. once you switch it off thats it for 30 hrs or so.
    With a full working key start the car switch it off again, within 30 sec insulate the key reader from the key contact (around the ignition) and the car should start and run.
  12. Doctor Bob
    Doctor Bob Grandpa
    Mornington Peninsula
    VT V6 Exec & VN V6 Exec
    ok guys here you go ... the truth
    the immobiliser will stay disarmed for about 30 seconds, thats why you could start the car, try it when the red light is flashing, it wont run.
    the key will under no circumstances loose its coding with the battery removed
    the contacts on the ignition barrel read the key in case the radio frequency section is dead, the contacts are also used to program the key.
    the time out is provided to allow the car to be taken to get a new key programmed if it dies completely, it will work any number of times if the system re arms
    Basically there is a good immobiliser system fitted to these cars.
    try it out, let the system arm (red light flashing) insulate the contact & try to start it.
    Vt has a different system it needs to read a good key to go
    hope this clears up some mis-information
    Rob
  13. Harts_94VR
    94 VR II
    And the truth shall set you free....
    Thanks a lot for such a good follow up Doctor Bob, obviously even the Holden guys didn't know all of that stuff. It's good to get the drill on this at last.
  14. stylin_vr2
    stylin_vr2 New Member
    hoppers, melb
    BF fairmont (when im allowed)
    hey thanks for this! my button hasnt worked since i got the car n just cant be assed forkin out 2 get it fixed!! even i (clueless..) can do it! yay!
  15. Wagon_Wheel
    Wagon_Wheel Drop A Patch....
    Mt Martha, Vic
    When I got my VR, it came with the original one button keyhead, and an after market 3 button one (2 Buttons did absolutly nothing lol), the 3 button one worked perfect and the originals battery is dead or somthin cause remote doesnt work, but it starts car etc. Then i got thrown in the pool with my good remote now its rooted, the only thing it does is manually open doors but it will not start car or anything, and i cant afford to fork out $80 for a new one, but i want my remote central locking back, is there any hope for it? or will all the components be rooted cause of the water?
  16. Doctor Bob
    Doctor Bob Grandpa
    normally if it stops working when wet it will not come good.the only way is to get a new one & get it programmed to the car
    Rob
  17. Wagon_Wheel
    Mt Martha, Vic
    Yeah, thats cool I kinda figured, thanks anyway
  18. Wong
    Wong New Member
    VT executive
    hi all
    anyone who know where can I make a new head keys for VT holden commondore
    I live in liverpool and I went to holden cabrammatta they charger $128 dollars for new key. please Anyone who know where it cheap?
    thanks
  19. djlingard
    djlingard New Member
    Barcaldine
    VZ Executive
    Hey doctor Bob is there any way to programe a 3 button key for a vx yourself??? just brought the key off ebay for 35 bucks and then realised holden hhave to program it for another 90 bucks.
  20. WAGON MAN
    WAGON MAN Gas Sleeper
    North Coast , NSW
    VX S2 Berlina Wagon with Phreddied bits.
    Sorry mate you cannot program the key yourself, it will need to be programmed.
    Btw, where are you located at?
