C
CDMA0428
Guest
If you leave a key in the ignition with the ignition switched on for 1hr and 30 min, you can then start the car and drive it home ( it's in limp home mode). it doesn't work the second time within 30 hrs. once you switch it off thats it for 30 hrs or so.
With a full working key start the car switch it off again, within 30 sec insulate the key reader from the key contact (around the ignition) and the car should start and run.
