change cam sensor
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by 94calais, Dec 11, 2010.
  1. 94calais
    94calais New Member
    ipswich qld
    03 5.7 vy ss
    hey guys, was told need to change the cam sensor, just wonderin can anyone tell me how to change it and where it is and looks like, any help on this would be muchly appreciatted, cheers
    oh it's a vt v6
  2. Krisp
    Krisp New Member
    perth
    D22 St-r Navara
    its held on with one screw on the timing cover above the crank seal. then just use a flat head driver to pry it out lightly
  3. 94calais
    94calais New Member
    ipswich qld
    03 5.7 vy ss
    do i take the pulley off the water pump to get to it
  4. Room42
    Room42 New Member
    hobart
    vr acclaim series 2
    There is a magnet in the timing gear that you change as well but you need to pull off the timing cover for that. Dont wreck your sump gasket when you put the timing cover back on!
