Changing brake light bulb problem
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by bazza13, Oct 31, 2010.
  1. bazza13
    bazza13 Member
    Auckland New Zealand
    vt ss 5.0
    Hi guys went to change the bulb for my rear left brake light undid the two screws near the boot rubber and then found the clip is holding it in on the inside of the light but I cant get my hand in to release clip. Am i missing something here? Is there another way? thanks :hmmm:
  2. Darcon666
    Darcon666 Evil is always around you
    At home
    The Wife
    This could help...
    2.15 REAR LAMP ASSEMBLY — SEDAN
    REAR QUARTER LAMP ASSEMBLY
    REMOVE
    1. Open rear compartment.
    2. Remove rear quarter lamp assembly to body
    attaching screws, refer to Fig.12B-30.
    3. Pull rear quarter lamp housing sideways out from
    panel so that locating peg on side of lamp assembly
    snaps free from retainer.
    4. While supporting lamp housing, remove back-up
    light bulb socket, turn signal bulb socket and
    stop/tail light bulb socket by turning socket
    anti-clockwise and removing.
    REINSTALL
    1. Insert bulb sockets into rear quarter lamp housing,
    ensuring sockets are correctly located and lock
    securely into place.
    2. Ensure that rear quarter lamp harness grommet is
    seated correctly. Assemble lamp housing to body,
    ensuring locating peg snaps into retainer and install
    and tighten attaching screws to the correct torque
    specification.
    REAR QUARTER LAMP HOUSING TO
    BODY ATTACHING SCREW
    TORQUE SPECIFICATION
    1 – 3 Nm
    3. Check rear lamp operation.
  3. bazza13
    bazza13 Member
    vt ss 5.0
    Sweet mate thanks heaps
  4. Subway
    Subway New Member
    VSII Senator 5.0
    I was struggling with this seemingly simple task today! I have removed the nuts from the screws, but the screws themselves are still in the plastic housing. I am assuming they need to come out of the plastic housing so the whole piece can be moved sideways? I tried lightly taping them out with a hammer but they don't budge! I didn't want to risk breaking the plastic so I thought I'd check here first. I doubt these screws have been removed since the car was made! I have never changed them as I would certainly remember seeing as it is so tricky, compared to how easy all the other bulbs are to change!
    Any tips on how to get the screws out? Assuming they need to come right out?
    Thanks in advance!
    Suby
  5. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    VF2 GTS A6, VS Calais 383 A4, VS Clubsport 185 A4
    You can't use VT/VX instructions for a VSII (assuming your ride description is accurate). You need to remove the THREE nuts from their retainers inside the boot and the light unit should just pull straight out to the rear. Perhaps you haven't removed one of the nuts.
  6. Subway
    Subway New Member
    VSII Senator 5.0
    Thanks for that. Your right, I thought I was in the VS instructions, I saw the right year, 1997, but missed the important part! That might explain why I had trouble removing it! haha!
  7. ashbox
    ashbox back in black
    The Car
    something black
    The vs should just be undo the screws on the inside of the boot and come out
