cost of fixing/replacing diff?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by vpcommo, Mar 9, 2009.
  1. vpcommo
    vpcommo New Member
    vr berlina
    my diff is starting to get a bit noisy and was just wondering how much it'd be to fix/replace? and also how much would it be to get an lsd put in?
  2. POVRTY
    POVRTY building 5L VB TH 400
    taree nsw
    VE SSV 6SPD WGN
    i can tell u that i was quoted about $700 to rebuild a diff and put the lsd in, however that was supplying my own lsd center. hope that gives u a bit of an idea
  3. hsvpunk
    hsvpunk volunteer firefighter
    Mornington, Vic
    vy ss II M6
  4. muggo05
    muggo05 New Member
    HSV VT GTS
    my uncle put an lsd centre in his ute for $500 fitted. some place in sydney, will have to ask him where
  5. vpcommo
    vpcommo New Member
    vr berlina
    if its noisy would it just need oil or does it need a rebuild?
  6. delfin82
    delfin82 New Member
    vs executive s1/ vz berlina
    is it noisy when accelerating or it happen when u reach 60kph?
  7. vpcommo
    vpcommo New Member
    vr berlina
    it happens when i reach 60
  8. delfin82
    delfin82 New Member
    not 100% sure but i think your diff gears the problem unless you take off the cover n have a look at the gear, cause bearing noise do this all the time where as gear noise started when you reach 60 n above.
  9. axemurderer101
    axemurderer101 Active Member
    Albany
    VY SS
    cost me $300 to buy a reconditioned lsd off ebay and $50 for oil, additive, gasket and gasket sealer. installed it myself not really that hard
  10. vs304
    vs304 New Member
    VS S1 exec 304 5speed
    i went to sa race and sam hooked me up with a fully customised lsd diff new axles, retensioned it to 180ftlbs(standard=85ftlbs)but it was costly at around $1700 but it works so well no effort required.
  11. vpcommo
    vpcommo New Member
    vr berlina
    how soon would i need to fix/replace the diff if its whining? its only happening when going around 60 and over, but worst from about 60-80 and in third
  12. Troy5L
    Troy5L building a lemon
    Mornington peninsula
    Gu patrol td42
    its probably the bearings that are wearing out, its a common problem in commodore irs's...will probably need a rebuild or if you dont have the money just get a second handy off ebay or wreckers and hope thats fine
  13. Azp
    Azp New Member
    VN/VR
    I got worn out second hand LSD for $150 that was only spinning one wheel. Did a bit of research and shimmed it up myself for free. Tight as anything when I got it in the car.
  14. Gstreiny
    Gstreiny New Member
    Horsham
    Vt wagon
    Cost me $150 fitted for my vt second hand from a wrecker
  15. c&cberlina
    c&cberlina New Member
    VZ Berlina,Vs Exec(track car). RA Rodeo 4wd.
    Nice thread dig! Nearly 5 1/2 years!! :)
  16. SavVYute
    SavVYute Active Member
    VY S V6 Ute Series II 2004
    It will probably outlast the rest of the car even though it's whining.
    More like....how long can I put up with this nnnnnnnnnnnnoise
