G
GMH 72
Guest
There's a guy in the USA who is re-designing original dash clusters to suit VY VZ Holdens GTO's Vauxhalls etc. He can program the dash to do anything, for instance he can set the tacho up as a rev limiter and custom build into it a shift light and beeper for when the tacho hits the pre set limit the shift light & beeper will go off.
Also the LCD window can be programmed to show all kinds of announcements & graphic pictures ie; when the tacho hits the preset limit a gear shift picture will show up in the LCD or you can have it say something else if you wish. It's almost endless because he can practically make it do & say what ever you like it to.
He has all different types of facia fronts & can even change the LED colors behind the dash to make it light up any color and also multi color as well as make the needles go different colors during the rev & speed range.
His web site is worth a visit and the blokes name is Chris White. He can import & export your dash from any where in the world.
Sorry heres the link i forgot to put it in - http://www.whiteautoandmedia.com/Content/default.aspxAlso the LCD window can be programmed to show all kinds of announcements & graphic pictures ie; when the tacho hits the preset limit a gear shift picture will show up in the LCD or you can have it say something else if you wish. It's almost endless because he can practically make it do & say what ever you like it to.
