DBA Choose Your Stopping Power - VS HSV GTS
Discussion in 'dba Brakes' started by dba Brakes, Jan 31, 2017.
  1. dba Brakes
    dba Brakes Member
    VY
    Launched in 1995, the VS HSV GTS packed a 215kW/475Nm punch that, at the time, was more than enough power to give its rivals a thorough scare. Today HSV fanatics will pay top dollar for a well-preserved VS GTS, with most owners asking above $25k for the opportunity to own one of the coolest Holdens to come out of the 90s.
    If you’re looking to replace the discs on your VS HSV GTS, here’s just a few reasons we believe the DBA Club Spec Road & Race 4000 Series T3 slotted rotors are the perfect performance replacement rotor for your VS HSV GTS.
    T3 Slot 48 precision CNC machined slots
    Advantage: Tri-Symmetrical curve slots dampens the vibration harmonics or noise.
    Benefit: A quieter, responsive and smoother brake pedal feel.
    Kangaroo Paw – 144 diamond and tear drop pillar ventilation system
    Advantage: Increased surface area resulting in greater heat dissipation.
    Benefit: Minimises brake fade and increases braking effectiveness.
    XG150 High Carbon Alloyed Iron
    Advantage: An increase in thermal capacity property allows the rotor to handle constant extremes of heat over extended periods of time.
    Benefit: Minimises warping and cracking and prolongs the service life of the rotor.
    Thermographic Temperature Monitoring
    Advantage: Heat paint markings change colour at specific temperature thresholds.
    Benefit: Allows the driver to monitor rotor fatigue and decide on rotor replacement and to assist resellers with warranty claims.
    Paint protection on non-friction areas
    Advantage: Reduces corrosion, enhances appearance.
    Benefit: Stops any unsightly rust formation.
    VS HSV GTS Front Rotor: DBA 4046S
    VS HSV GTS Rear Rotor: DBA 4047S
    For other model years, please check our online catalogue - http://www.dba.com.au/catalogue/online-catalogue/
    At DBA, we pride ourselves on making a wide variety of specifications from street and light track applications to 4WD/SUV applications all the way to race-bred applications. We also take great pride on making brakes to suit almost any make and model.
    Using our online catalogue, we make it very simple to find the parts available for your vehicle. Just enter your car’s details as seen below and not only will you see if we make something for your vehicle, in most cases you will see many alternative options for your vehicle depending on your application and driving style.
    Find our catalogue here: http://www.dba.com.au/catalogue/online-catalogue
    If your make or model is not listed, feel free to send us a PM and we will check to see what is available!
    For more information visit: http://www.dba.com.au/
    LINKS
    DBA Official Website
    DBA on Facebook
    DBA on YouTube
