Diff swap to sedan
magnetvh
VH SL/E 381pack
G'day people.
Before i buy it, Can someone shed some light on wot mods I have to do to fit a wagon V8 10 bolt LSD diff into a sedan.
Thanks
Mick
SL/ENUT
The SL/E Fanatic!
41
Burnie, Tasmania
VB SL/E 5L
Don't do it. Its a tad more wider than a VL sedan diff.
ajvx01
North east Adelaide
308 vc
Cheers^ had always wondered if they were different!
SL/ENUT
The SL/E Fanatic!
41
Burnie, Tasmania
VB SL/E 5L
My VB currently has a wagon diff in it, with the sedan shocks, rear stabilizer bar welded on. Looks ugly welds too. Always have the left hand side rear tyre rub on the wheel arch lip. An adjustable pan hard rod is useless cause the right side would rub then.
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
plus the shocker set up is not the same.
why?
Wagons don't have rear sway bars coz the shockers and the angle they are installed
are meant to assist in stopping sway. Their mounts are also on the wrong place
for use in sedans...
magnetvh
VH SL/E 381pack
Oh bugger. Gota keep lookin for a sedan one round here then. thanks for the info guys.
180sc
deception bay
VS Calais & vh sl
The diff i put in my wagon was a vl 3.45 28 spline that measured exactly the same as a sedan diff and the same went for a vc i used to have it was a sedan with a wagon diff and was lowered with 245/60r14 on 8 inch rims with no scrubbing at all. also all 3 wagon diffs had sway bar mounts on them but the body's had no mounts.
ajvx01
North east Adelaide
308 vc
See this is the thing... There's so much confliction with first gens. I was told a psteering k frame was different to manual steer. It's not at all, it all fitted up schmick!
SL/ENUT
The SL/E Fanatic!
41
Burnie, Tasmania
VB SL/E 5L
3.08:1 LSD 10 bolt wagon diff, out of a VH Commodore. As you can see, no rear stabilizer mounting points. Also, the rear shock mounting points. My VB has the sedan points welded on to the area thats normal wagon ones go.
Aussie V8
VC SL/E 308/T350. 1989 FJ75 Toyota Troopcarrier
Sorry to tell you but they are different. Fitting "up schmick" tells me you have fitted the exact same type that come out of it.
