Disassemble front hubs, is this possible
NeddyBear
Veteran Mountain Biker
Rubyvale, Qld
2004 2.5L Subaru Outback
Just as a matter of general interest is it possible to dismantle a front hub assembly with ABS.
Not to remove the hub from the vehicle but to actually dismantle to hub. I don't want to repair it but would be interested to see how it's assembled.
Immortality
Staff member
Sth Auck, NZ
I was told not but then nothing is impossible, rather is it worth the time/effort/cost?
_R_J_K_
Zenki S14
I suspect you will need a press to do it. From that picture it only looks like it will be 3 or 4 parts anyway: the hub face which is just a round hunk of metal with studs, the bearing, the bearing carrier which again just looks like another hunk of metal, and the ABS sensor. There might be an ABS rotor you can remove but I suspect they just cast it into the hub face.
NeddyBear
Rubyvale, Qld
Thanks guys, I'll check out the wreckers and take a decent look at what makes it do what it does.
_R_J_K_
Zenki S14
What exactly do you want to know?
