Do I need to roll guards on 17 inch wheels on sssl
JohnRossii
19
Australia
VZ berlina
Lowering car on ssl front sssl rears on 17 inch wheels do I need to roll guards cheers
ephect
Donating Member
VS Acclaim V6
Depends on the offset of the wheels. Holden rims shouldn't need to..
Guessing no camber kit? It'll wear on the inside (bad) and give you the clearance needed not to roll your guards (good)
JohnRossii
19
Australia
VZ berlina
Yeh it’s just on my stock vz calais rims atm so hopeuflly won’t have to
ephect
Donating Member
VS Acclaim V6
Might as well check the clearance you have now, you'll know if you need to roll or not.
Alternatively remove the spring and let it down slow to check clearance
