Drum brakes to Disc brakes conversion
Discussion in 'VL Holden Commodore (1986 - 1988)' started by sheepz89, Aug 11, 2008.
  1. sheepz89
    sheepz89 New Member
    '04 Holden VY II SS
    Hey guys just wondering if anyone has done this...
    i know its easy, just need to know what im gonna need...
    Thanks!
  2. mulligan-can
    mulligan-can ?!?
    Cairns, QLD
    VS S Pack Ute
    Complete rear diff assembly basically. Easiest way (maybe only?) way to do it is just swap the drum brake setup for the disc setup (axles, diff and all).
  3. jatsvl
    jatsvl NEEDS MORE POWER!
    vl exec wagon
    as above is the quickest and easiest way and quite possibly the cheapest too, you can do just the brakes but buying all the parts will be dearer than buying the whole diff assembly.
  4. VL Berlina 5speed
    VL Berlina 5speed Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    its possible to convert it to disk using vn brake parts but pricing is the key
    i payed $200 for a complete disc rear end
    i also priced up all the parts from 'u pull it' and the cost was basicaly on par with a complete rear end
    so i ended up just getting a whole rear end;)
  5. madrx3boy
    madrx3boy New Member
    New Zealand
    98 VT Acclaim
    over here in nz the disc rear setup is pretty hard to come by. so if anyone could tell me (and the guy who started this thread) what parts are required to convert a drum rear end to disc brakes and how to do it, or if you have a link to a thread on this topic already, please let us know.
    i am probably guna put vt discs on the front of my vl, should i put vt discs on the rear straightaway or will vl rears do?
    cheers
