flexplate replacement
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by fishman, Jan 31, 2008.
  1. fishman
    fishman fishman
    east coast tasmania
    VN Executive Wagon S2runningVP motor on dual fuel
    howdy, anyone ever done a flexplate or anyone had a problem with one...
    sounds horrible
  2. Cheap6
    Cheap6 New Member
    VP Exec
    Yep. Quite common. 'Box out, unbolt flex plate replace.
    If it's the VP or the VN is S2, the bell housing lower cover "beaming brace" needs to be refitted with the bolts to the gearbox finger tight (or the 'brace clipped to the housing) before tightening the 6 nuts on the sump studs, with the height of the sump studs even, to avoid a repeat failure. (The beaming brace can cause the joint between the trans. and motor to "hinge"). New flex plate to crank bolts are required and they have to be torqued (with a torque wrench) + the specified angle (which i would have to look up) to tighten.
  3. jules
    jules we like the bun
    pimpin
    i've done it.
    you can do it in a day although it's painful. you need to get the box out as Cheap6 said, which means getting the starter motor out, which means getting the LH headers out from memory, also the exhaust section behind it.
    if you don't have a commercial hoist or pit, then you're using car stands like i did and you will develop bigger arm muscles.
  4. fishman
    fishman fishman
    east coast tasmania
    yeah g'day 400 bucks supply new flexplate fitted with pennzoil gearbox fluid replacement
