Fuel Pump
Discussion in 'VY Holden Commodore (2002 - 2004)' started by knight97, Mar 2, 2007.
  1. knight97
    knight97 New Member
    was vn s pack now VY S2
    Has anyone done a fuel pump in a VY series 2??
    Is this a common prob with VY's??
  2. holden007
    holden007 VRII
    Subaru Liberty
  3. 392RWkwSS
    392RWkwSS New Member
    VY Exec S2
    i heard from an ex holden tech that with the fuel pumps in the comodores since they sit in the fuel tank you shouldnt run the fuel tank right down to nothing because the fuel pump will run dry instead of being lubricated by the petrol in the tank. he said that u shouldnt run below a quarter tank.
  4. kaps
    kaps New Member
    vx 2
    There was a recall on the fuel pump sender units or MRA . VX-VY
    To remove the pump the tank must be removed .
    It take around 2 hour to remove and replace the MRA
  5. knight97
    knight97 New Member
    well I had a VN 16 years never did a fuel pump
    A VY 4 days...........
    You guessed it a fuel pump & it took 3 days for holden dealership to source one!!
  6. klink
    klink New Member
    vx
    Glad im not paying your labour bill.
    three bolts on the straps holding the tank in place, remove fuel cap, remove hoses.
    drop tank gently tap the top of the fuel tank where the pump is remove carefully undo hoses, and clips, remove pump, install new pump conect it up put back in tank, connect hoses put tank in place do up 3 bolts.
    hour tops, just make sure that you have about 1/4 of a tank in it for balast.
