[LS1] Fuel rails etc etc...
NOWORK_CALAIS
Vy S2 Calais
Hi all
Fairly new to the world of ls1's and have recently brought a rebuilt/worked motor to swap over with my current one.
Previous owner has put a 102mm lsxr manifold on it with 50lb injectors and areoflow fuel rails and a fuel pressure reg/gauge and just trying to work out how the fuel lines will need to be run.
Any help would be much appreciated.
07GTS
Australia
VEGTS BUILT BLOWN E85
run fuel pressure at 58psi u should be able to get a line fitting to go from clip on factory line to the new rail and a return line will be needed, if u use the vac reference regulator u will have to adjust the tune accordingly or just leave at flat 58psi and either way u will have to change the tune to suit the bigger injectors, or just use the factory reg setup in tank then just connect line to rail
NOWORK_CALAIS
Vy S2 Calais
yeah thanks for that. Do you no if it is a pain in the ass to run a return line
07GTS
Australia
yea probably would be u would have to tap into the top of the sender module with a new return line so could get messy if not sealed properly ect
