Gouldinator1's Sv6
SUP3RST4R_DJ
Orange
2011 MY11 Holden VE SSV Ute
that paintjob looks pretty trick man, howd you get the pattern like that? also was it hard to do the engine covers? ive been wanting to do mine for a while aye haha
Gouldinator1
Strip Sack, Miller!
ACT
VZ Sv6
The pattern is pretty simple to create. Once you have the black undercoat done you create the effect by pulling the silver coat off. Once the silver coat is sprayed and while it is still wet you use a piece of plastic with the same consistency as that of glad/cling wrap (note: I found that cling wrap actual pulls the paint, it sticks too much and is messy, doesn't give a clean effect than just normal plastic) to cover the object. Then you pull it off, it will take some of the silver paint off and that will show the black underneath.
The engine covers were the second piece I did and was pretty simple. You just have to make sure you clean, sand and prepare them correctly. Then it is a simple matter of painting them. It isn't difficult.
Gouldinator1
Strip Sack, Miller!
ACT
VZ Sv6
Another piece of the puzzle all painted up.
Gouldinator1
Strip Sack, Miller!
ACT
VZ Sv6
Last piece of the puzzle all done and painted.
Been a bit busy but should have a big update soon.
Gouldinator1
Strip Sack, Miller!
ACT
VZ Sv6
Finally got new rims, tyres and suspension through my car.
List of new goods.
HSV VE GTS Rims
Achilles 245/30R20 (93W) ATR Sport tyres.
Painted Calipers, red.
Koni Yellow sport shocks
Lovells Springs, Superlow in rear and lows in front.
Superpro Brushes
Camber Kit
Whiteline Rear and Front Swaybars
Whiteline Strut Brace
Here are some pics:
Guess I should update the front.
Gouldinator1
Strip Sack, Miller!
ACT
VZ Sv6
Yeah I figured that was the piece but it has sort of grown on me as the paint has worn in. I think I will leave it for now, maybe in the future I will redo it but it is ok.
Gouldinator1
Strip Sack, Miller!
ACT
VZ Sv6
Haven't been on in a while but have a few updates.
I covered the parcel shelf in sound deadener. The stuff I was using is Focal BAM. It is a little lighter than dynamat but has a foam lay on the top, perfect for vibrations in the trim.
Here a few pictures...
