Growler Advice
ShawrySS
Gold Coast
2005 VZ SS
Hey guys, quick one. Would a VX SS growler kit fit a VZ SS?? They are both LS1 however wanted to double check before spending $$$. Cheers.
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
Use the search function and do some reading Growler kits are ****
They are commonly referred to as "SS Reductions Intakes" and have actually been proven to reduce horsepower
You would probably get a better gain by just fitting a K&N Filter in your original airbox
If you want to improve performance an "Over The Radiator" cold air intake and tune is the way to go
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
Stick with the stock intake it really is all you need on a fairly stock VZ (intake is much better then the earlier models. Bigger piping and bigger MAF.) I just put a Monaro cold air intake and made a second hole on mine. Fairly stock but still put down 280whp.
