Headlight beam adjustment
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by daveb8, Jul 1, 2005.
  1. daveb8
    daveb8 New Member
    VZ Executive
    Hi all, my headlights point into the ground a bit and they really need to aim higher. I've seen the two diagrams on the top of the lights that say "left / right" and "up / down" with arrows going clockwise and anticlockwise, but I can't work out what to turn. I can see a few screws but when i turn them nothing moves. Thanks for your help guys :)
    ps. i've attached a picture that may make things a bit easier...
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7
    At the back of the headlight there are 2 screws with knobs on them that you can turn by hand. the knob closest to the bottom of the lamp is for vertical adjustment and the knob closest to the top is for horizontal adjustment.It is best to have them aligned professionally.
    Regards
    Jerry
  3. R1SKY
    R1SKY New Member
    Hi can i ask where are the knobs are you talking about? im confused could you please high light it or place an arrow on the picture above
  4. accentstencil
    Eschol Park, Sydney
    WH II Caprice, 5.7
    I just checked mine and they are philips head screws and not knobs as I thought. There are 2 cut out parts on the metal part above the lights, if you look down from them you will see the adjusting screws. I'm in a hurry now and will supply photo later.
  5. accentstencil
    Eschol Park, Sydney
    WH II Caprice, 5.7
    Headlight adjustment screws.
    Here are the positions of the headlight adjustment screws.
  6. R1SKY
    R1SKY New Member
    Thanks for the pictures sure helped me
  7. accentstencil
    Eschol Park, Sydney
    WH II Caprice, 5.7
    No problem.
  8. minux
    minux Infidel Bear
    oh dear, another person who will be driving around with ass about lights.
    Can you at least make sure you get a calibration chart and make your lights sit level so you do not blind us other road users at night with your own incompetence?
  9. lout
    lout Active Member
    Langwarrin Victoria
    VX Executive S2
    I found an article years ago to align headlights, basically at night find a level road with a wall (roller door) at end (factory driveways are usually perfect) drive up to wall as close and straight as possible place a sticker dot or masking tape cross (+) in centre of light beam where each light shines on wall, back up 8 metres place a piece of cardboard, rag over one headlight (don't leave too long it gets mighty hot) then adjust other side you want high beam left/right (Horizontal) exactly centre and up/down (Vertical) 2cm down from sticker, repeat for other side. Andrew
  10. calais_304
    calais_304 New Member
    98' VT Calais s1 - 195i
    sweet as i'll have to check mine when i get a chance, i hate driving around at night with no light(well i do but it's like their sitting 1m infront of the car)
  11. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Prado
    Just make sure that you have it on high beam when adjusting as the low beams will be in the correct position if the highs are straight, otherwise you will be possum spotting on high beam.
  12. nathanVY
    nathanVY such boost
    Geelong, VIC
    2003 VY LS1 Turbo Calais, 2005 4Gen Liberty Wagon
  13. Troy711
    Troy711 Retired Old Fart
    Canberra, ACT
    2011 Mitsubishi Pajero GLS
    ^^^^ You're 5 years late bruz.
