J
jliu66
Guest
Hi, my friends,
I have a problem with my 1999 Toyota Camry LE:
both headlights do not have high beams when I turn the signal lever knob to high beams. I went to the mechanic. He told me it is bulb problem. Then I use the new one for both sides. It still does not have the high beam. Low beams for both sides are ok. I also found that the connector is dirty. Then I cleaned one of them. I put old bulb and new bulb in. It is still the same problem. They only have the low beams but no high beams.
What else could have cause this problem? Connector sacket or electric wiring?
Light bulbs: HB2 60/55 Watts H4
Any helps are great appreciated!!!
Best regards,
John
Best regards,
John
