HELP How to clear "SERVICE VEHICLE SOON"
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by jetzboy, Aug 19, 2008.
  1. jetzboy
    jetzboy New Member
    VZ Lumina
    How do i clear this off the dash screen. Its so anoying evert time i pull up at the lights it comes on and beeps its driving me crazy. HELP PLEASE
  2. nicko
    sa
    75 cruiser ute
    should be in the service book, its a combination of the up and down buttons and mode
  3. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    search button is very handy but anyway,
    hold up and down, turn ignition on, wait for confirmation, then hold set until it says its clear
    Turd Ferguson likes this.
  4. BLACK VZ SS
    BLACK VZ SS New Member
    South Australia, Adelaide
    2005 VZ SS
    I don't think its to do with the service. Its an issue which occurs relating to emission.
    Need to get it checked out from Holden or someone who can plug their laptop into the cars computer to see what the fault is.
  5. VYClubby
    VYClubby Proud Clubby Owner
    294rwkw Oztrack Tuned 220 cam
    Yep, sounds like something is wrong. If it was just a service reminder it only comes on when you turn the car on or off. Not when you stop at the lights.
  6. andyman
    Orange, NSW
    its actually a error caused by the export vehicle software being loaded onto the computers, my post is to reset it, not fix
    to fix it, the ecu, bcm, instrument cluster needs to be re-flashed with updated software
    edit: just re-read and noticed comming on at lights, which is a little weird,
  7. Hoarey
    Hoarey New Member
    VZ Executive
    jetzboy im having tha same problem mate. im still pretty new to VZ, but andyman wat exactly does it clear if you hold own those buttons?
  8. andyman
    Orange, NSW
    hold up and down, turn ignition on, wait for confirmation, then hold set until it says its clear,
    that should reset the '45,000km service etc' or 'service vehicle soon',
    if it comming up with 'check engine' or 'emissions error' etc, that will have to be reset with a compatible scan tool or sometimes disconnecting the battery will reset the code if its a one off fault.
  9. Rhemmy
    Rhemmy Rhemmy
    VZ S pac ute
    please help
    My ute does the same but not at the lights, just every 3-5 minutes. I have resulted in turning up the music...
    I have tried doing the reset buttons and even taken it into a Holden place to get the computer hooked up to reset it that way, neither works for me. Everyone suggests a resolution but so far none have worked. Does anyone else have an idea?
    I have tried: reset buttons
    taking it to the Holden department
    cleaning and replacing the filter- Holden suggested
    checking the oil sensor- another holden suggestion
  10. Chickenboi999
    Chickenboi999 New Member
    Newcastle NSW
    VE Calais Sportswagon S2
    1 dont listen to holden, less work is better work according to them
    2 holden mustnt of done much i had this problem & took to my local mechanic (NOT HOLDEN) & they were able to clear it
    3 holding in buttons clears on some cars but not all your Lumina should have the option though
    I suggest get a tech 2 on it there good gear!
  11. Kal123
    Kal123 New Member
    VZ SV6 && 180sx
    Try ultratune. They removed this error for a mate of mine using there scan tool.
  12. Calaber
    Lower Hunter Region NSW
    CG Captiva 5 Series 2
    This has been dealt with on other posts.
    You can't clear the SVS message with your dash buttons. The fault is often a dud oil pressure sender switch, located on the base of the oil filter. It requires a special socket to remove, costing around $18 from Repco, and the switch is about $120 and I think, only available from Holden. It is a very common fault with Alloytechs and this is probably the most likely cause of the error message. Replacing the switch (if it's faulty) will clear the message.
  13. mattsv6
    mattsv6 New Member
    VZ SENATOR
    100% Correct. Listen to this man!
  14. DeathVZaudiO
    DeathVZaudiO New Member
    Laverton
    VN V6 Exec Sedan
    To reset my service alert i hold down the two arrow keys, turn the ignition to the on position without starting the car and it beeps and says Reset service or something and then i just hold down the SET button for about 20 secs max, that clears it.
  15. Calaber
    Are you talking about the service interval message (ie 60,000, 75,000 etc) or the "Service Vehicle Soon" message? The interval message can be cleared via the dash keys, the other one can't because it is telling you there is a fault somewhere and won't disappear until the fault is fixed.
  16. PaulSV6
    PaulSV6 CHE Tuned 156.8rwkw
    Castle Hill
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Yes ur normal service intervals can be reset by the user. This thread is about the "Service vehicle soon" Msg, which cant be reset & has to be dealt with by Holden or a mechanic with Tech 2.
  17. DeathVZaudiO
    Laverton
    VN V6 Exec Sedan
    Ahhhh, excuse my ignorence, gotta slow down and read this stuff proper like.
  18. blnls1
    blnls1 New Member
    VZ SS M6
    It's not a service light!!!! It's a warning, There is a fault in the emission control system. Usually the fault is the oil pressure switch. I'm a mechanic and 90% of the time it's the oil pressure switch. It's on the front of the oil filter housing. 2 min job to change. But you will have to get the fault cleared from the ecm memory.
    Hope this helps
    Bart.
    I assume it's a alloytech v6?
  19. fred321
    fred321 New Member
    VS SS 5 Litre
    hi guys i have a 98 vt v6 wagon. It comes up with error in the instrument cluster. After a few k's of driving all the warning lights come on and the thermo fans go to a high roar. I took it to my mechanic and they said its a fault with the cluster. So they got me a good seconhand one with lower k's and fixed it for about a week. Now it comes and goes. The error code. The only codes they could get out of the ecm was "anti theft derterent signal missing." ? Can any one help? Cheers.
  20. colin-commodore
    colin-commodore New Member
    Bunbury
    VZ SV6
    100% correct. Switch was $92 from Holden and $20 for the kinchrome oil pressure switch socket. Took literally 2 mins to do. Ps. Don't do it once you've been driving alot of hot parts -.-
