Kal123
- Mar 4, 2008
- 766
- 7
- 0
- Location
- Townsville
- VZ SV6 && 180sx
Try ultratune. They removed this error for a mate of mine using there scan tool.
This has been dealt with on other posts.
You can't clear the SVS message with your dash buttons. The fault is often a dud oil pressure sender switch, located on the base of the oil filter. It requires a special socket to remove, costing around $18 from Repco, and the switch is about $120 and I think, only available from Holden. It is a very common fault with Alloytechs and this is probably the most likely cause of the error message. Replacing the switch (if it's faulty) will clear the message.
To reset my service alert i hold down the two arrow keys, turn the ignition to the on position without starting the car and it beeps and says Reset service or something and then i just hold down the SET button for about 20 secs max, that clears it.
