Help Installing a Boost Gauge on vx supercharged 6
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by tynuts, Dec 27, 2006.
  1. tynuts
    tynuts New Member
    VX SUPERCHARED S s2
    Can Anyone help me with were the hose from the boost gauge connects to the supercharger.
  2. snoopin99
    snoopin99 New Member
    Outer SE Melbourne
    VT Calias S/C Series 1
    Boost gauge connection
    On the passenger side of the supercharger, under the plastic cover there are some small plastic hoses towards the rear of the supercharger, they have rubber boots on the end of them, one connects to an actuator valve that connects to the supercharger. This hose is the one you want. It is the bypass actuator for the supercharger and it gets a feed from the manifold. If you need a photo i can supply one but it will be a pain in the but:ranting: as i will have to go pull my cover off and take one for you.
    Hope this helps, Andrew :yeah:
  3. sixshooter
    sixshooter New Member
    2x VS
  4. mcgyvah
    mcgyvah try it & see
    stock Supercharged VT S series I
    Tynuts, Just wondering if the bypass hose worked.
    I thought this actuator operated under vacuum? (please be nice I am easily misled)
  5. mcgyvah
    as i have been impatiently awaiting a reply to this thread for a whole hour... :)
    I decided to tee off this bypass actuator hose and fit my gauge and see what happened.
    It read a nice vacuum at idle , and ,when I temporarily taped my guage to my bonnet and went for a drive it manage to just nudge the positive about 0.1PSI at full acceleration to redline in 1st and 2nd.
    I thought i might try attaching it to the manifold as is also suggested.
    Any idea how to get that rubber plug in the manifold off without breaking it? as I will likely need to put it back.
  6. Bluewildangel
    Bluewildangel New Member
    Vt II supercharged
    here ya go if you need anymore pics just ask :thumbsup:
  7. mcgyvah
    thanks for the pics,
    is that the your boost gauge coming of the white nylon tee?
    I put the tee in the hose above this which goes between the sc and the actuator, maybe i used the wrong hose?
    sixshooter... i haven't found that m90 webpage yet, i'll look somemore tomorrow.
  8. shaggerz
    shaggerz New Member
    Victoria Point, Brisbane
    2004 VY2 SV8 A4
    It is very easy to use the vacuum nipple on the front of the manifold. That is where mine is attached. I found that the plastic cap broke when I took mine off, as they all go brittle with age anyway. Just attach a bit of hose to it and fold it over on the end and clamp with a cable tie if you arent ready to install the gauge yet.
  9. Charg'd
    Charg'd New Member
    in a ford
    ford
    i used the vacuum line on the front as shaggerz said, it gives me an accurate reading, & is easy to fit, although dont be suprised if the black rubber cap breaks when you pull it off, mine did, if you need pics, just ask i will post some for you
  10. Bluewildangel
    Vt II supercharged
    Yeh the white tube going to the back of the engine is to the back of the boost gauge the tea piece came with the boost gauge (Autometer)
  11. scbh81
    scbh81 VRUUUM XU6 180 SC
    St Kilda Victoria
    HSV XU6 VTII 99
    yeah mate some pics would be great!!!!!!!!!!
  12. ch1mp
    ch1mp New Member
    If you have a valid reason for requiring my locati
    VT S-Pack 3.8L Supercharged
    ye i'd like to know too coz i'll be putting one in mine. but which gives a better reading? the tube from the actuator or the one on the front of the supercharger?
  13. Just Big Mac
    Just Big Mac New Member
    Bellbowrie Brisbane (South West)
    WH Statesman V6 S/C
    Hey Charged, Could you please send me some pics of your boost gauge line on the front of the LIM
    Thanks in advance.
    Just Big Mac
