No dipstick there a rubber fill plug up on the drivers side of the tranny and a sump plug in the base of the tranny.
If you drop the pan and change the filter it should take around 6.3litres of DEX VI
Start with 6 litres filling through the rubber plug.
Run the car through all the gears and wait till the trans fluid temp is between 30-50degrees, monitor this by using engineerining mode and scrolling down to transmission sump temp.
Now while the engine is running remove the sump plug from the transmission base and if no fluid comes out slowly top up till it begins to drip out. If fluid gushes out its overfilled so wait till it slows to drips then replace the sump plug.
Changing the filter is straight forward just pull it downwards and out....
Nice work, feels good to do it yourself yeah
