How To Convert Hp To Kw
Garth
Your guess is as good as mine......
46
www.justcommodores.com.au
100 series Toyota Landcruiser V8 monster
ive come accros this, you might like to try this
to convert hp to kw use the following as a example
150hp =xkw
you go like this 150 x .746 = 111.9kw,
so, the old vn is 125kw, then to work it backwards in hp you would do the following
125kw x 1.34 = 167.5 hp, not bad
once again, to get a hp figure into kw you multiply hp figure by .746
to get a kw figure into hp rating you multiply by 1.34
or there is this one, to get torque at any given time
hp=torque x rpm/5252 you transpose that formula to be the following
you go like this,
torque = hp / rpm x 5252 / is devide
we have the hp listed above, 167.5hp, rpm, let's say that's at 2.2k (2200rpm)
you go, 167.5 / 2200 (then hit = button) then multiply answer by 5252 and you get torque, expressed in nm in this formula it's 399.868nm
once again, you need to transpose the formula hp=torque x rpm / 5252 to get torque formula of torque = hp/rpm x 5252, remember, the rpm is the only variable in this formula, hp and the 5252 are not variants
cheers
garth
have fun playing with this
AirStrike
91' VN SS
Yeah I got a few more, just a quick break down tho.
KiloWatts ---> HorsePower = Kw * 1.355818
HorsePower ---> KiloWatts = Hp * 0.737562121169655514235686500695521
Cubic Inches ---> Litres = C.I * 0.0164
Litres ---> Cubic Inches = Ltrs * 61.02374
Miles per hour ---> Kilometers per hour = M.P.H * 1.609344
Kilometers per hour ---> Miles per hour = K.P.H * 0.621371
Torque ---> HorsePower = (Torque * RMP)/5252
HorsePower ---> Torque = (HorsePower * 5252)/R.P.M
Bore + Stroke ---> Displacement = Bore diameter^2 x .7854 x stroke length x number of cylinders
Some may seem stupid but these are not rounded and give the exact value.
AirStrike
91' VN SS
You can also combine them for example;
but u can use the equation for KiloWatts ---> HorsePower if you know ur car in kW
OSL-060
Banned
42
SE QLD
Or......
Just download this great little conversion calculator I've been using for awhile
http://www.joshmadison.com/software/convert/dl.asp
It's only 152k, so it doesnt take long to download- even on crappy dial up
Hope it comes in handy
Jake.
OSL-060
Banned
42
SE QLD
Ok, I dug this up from the depths of my documents. Just a little page of basic conversions and racing formula's I made awhile back.
O
onezero
Guest
http://www.esbconsult.com/esbcalc
The program downloadable from the above site will convert everything and anything.
Also, to be used for estimation, RWHP can be seen as flywheel KW. (autos have approx. 30% drivetrain loss, manuals 25%, on the other hand FWD's are 15-20%)
