HSV GEN-F Clubsport/Grange/GTS/Maloo/Senator 2013-on-SAFEBRAKE Performance Hoses
Discussion in 'SAFEBRAKE Performance Brake Lines' started by braidguy, Aug 23, 2016.
  1. braidguy
    braidguy Member
    Give your HSV GEN-F a real brake bite for more enjoyable driving!
    "Effective brake upgrade, with improved stopping power for your car"
    "Regardless the size of your discs or number of pistons in your calipers"
    Our Key Advantages:
    • Unrivalled flex-life (18 million normal cycles) for exceptional durability.
    • Minimal volumetric expansion (hose swelling) due to 3.4mm Heavy-Wall designed which results in powerful braking and amazing feel.
    • Negligible water ingress, meaning brake fluid is not contaminated and performance is not compromised.
    • Long service life while maintaining the same high level of braking performance.
    • Safer motoring - Improved braking performance over standard rubber brake hose.
    • Unrivalled braking performance for track and racing application, regardless of the size of brake rotors and calipers.
    Product Code:
    HHSV-GEN-F.4B
    HSV GEN-F 2013-On
    Applicable models: Suits HSV Gen-F Clubsport, Grange, GTS, Maloo, Senator, with AP Racing/Brembo/Harrop 6-pot front calipers, and 4-pot rear calipers.
    Compatible calipers: AP Racing/Brembo/Harrop 6-pot front & 4-pot rear calipers
    Compatible fluids: DOT 3, DOT-4, DOT 5 (Silicone), DOT 5.1 (Glycol Ether/Borate Ester)
    Includes in the packaging are:
    Front left axle = 1 hose
    Front right axle = 1 hose
    Rear left axle = 1 hose
    Rear right axle = 1 hose
    Total: 4 hoses kit.
    following documents:
    - Warranty Card
    - Suggestion for Safety
    - Limited Warranty (Terms & Condition)
    - Installation Suggestion
    Installation Note:
    This SAFEBRAKE brake hoses kit fit like standard part, without modification required.
    5 Years Warranty
    Our Quality Commitment: When you purchase SAFEBRAKE® brake hoses, you get peace of mind knowing that you are entitled to five years warranty. Even though we are confident that our product will last the lifetime of your car, we offer an active 5 years warranty so we able to monitor your satisfaction in using our product. The warranty will give you full replacement of the product should there are defects due to manufacturing. (Please refer to our Warranty Terms & Conditions)
    This is our commitment to ensure the reliability of our products and quality acknowledgement. Thank you for your kind support.
    SAFEBRAKE
    Available for most Holden Commodore cars and more.
    PM me for price & delivery.
  2. dgp
    dgp Active Member
    Warrnambool
    VF II SSV Redline
    No HSV has Brembo calipers, they are all AP Racing (in the last 10 years anyway).
  3. dgp
    dgp Active Member
    Warrnambool
    VF II SSV Redline
    Double post
  4. braidguy
    braidguy Member
    Thanks for your valuable info mate, I have made the correction.
  5. dgp
    dgp Active Member
    Warrnambool
    VF II SSV Redline
    Braidguy, I must apologise the VE GXP Maloo had the Brembo's calipers, same as what the Holden Redlines have.
  6. braidguy
    braidguy Member
    No worries mate, the banjo fittings on our HSV kit fit all Brembos, Ap Racing and Harrop calipers.
