Kicker CVT shallow 2 ohm or 4 ohm
VHCOMMO87
VH SL/X
Cheers sweefu, yeah im gonna get the 1 x 2ohm to begin with and then later down the track get another 2 ohm
Cheers all.
sweefu
VY Berlina V6 / R31 Skyline
Make sure you get an amplifier which is 1ohm stable, in that case.
StoneX
44
Hastings
VE Calais-V 6.0L
That is why I recommended two 4 ohm subs as 2 ohm stable mono amps are much more common than 1 ohm stable mono amps required for two 2 ohm subs.
Maybe go read some of this website... Basic Car Audio Electronics
sweefu
I didn't read this at first, right you are. Either 4ohm subs and 2 ohm stable amplifier, or 2ohm subs and 1ohm stable amplifier (if you plan to have 2 of each later) as Stone said, 2ohm stable amps are cheaper/more readily available than 1ohm stable.
VHCOMMO87
VH SL/X
cheers guys for all this info, ok 2 x 4 ohm it is with a 2 ohm stable amp. And all this can be done with single coil subs?
StoneX
44
Hastings
VE Calais-V 6.0L
Yes... When you buy the first sub and the 2 ohm stable amp the amp will just run at 4 ohm until you put the second sub in parallel.
VHCOMMO87
VH SL/X
cheers mate, what size amp would you suggest, the kicker cvt subs are 400 rms and 800 peak.
KAL SPL
46
Orange Nsw
www.cardomain.com
Blown VS Calais !!
Any amp that has a rating of 800rms ish @ 2ohm will be perfect , just make sure its reputable brand , prob going to be around $500 mark for that much power and quality.
AmmoJammo
Adelaide, Australia
VL Wagon
I was making the two 2ohm sub suggestion based on using an amp from Jaycar :p the Kenwood 2ohm stable, 900watt rms amp is cheap and nasty.
VHCOMMO87
VH SL/X
thank you, so with a amp that is around 800rms @ 2ohm will the give me 400rms per sub?
Will that sound just as bassy and just as loud as 2 x 2ohm subs at 400rms per sub?
Cheers for all ya help.
