Low compression 3 of 6 v6 and manifold petrol washing on 3 only
Cruisy2650
Holden vz 2005 omega v6 alloytec
Please help I have low compression on drivers side 3 cylinders 25psi after wet test 50 psi max ..
petrol washing on same side manifold ports
Could one chain side be out timing cause this ..?
MACE
Hi Cruisy2650,
My sincere apologies for the delay in getting back to you. I hope that your problem has been resolved.
Going by your member ride, which is either a VZ V6 or VE V6, then it would likely be caused by the timing being out.
If you have any more questions please don't hesitate to ask.
Kindest Regards,
Steve
Cruisy2650
Hi Cruisy2650,
Kindest Regards,
Steve
Steve,
Thanks for reply no luck I re done timing and still low compression on r/h side cylinders all 75,70,75 psi
L/h side 145,135,140 psi
I see new water pump been replaced and head gasket has no visible breaks but I'm wondering if gasket is stuffed, not sure on these mls type gaskets ..
Could it be head gasket, I took r/h head off just did a water leak yeast on valves and no leaks, have not done a head off pressure test yet..
Gasket looks like mostly all the rubber type seal that sits on surface is missing or worn off..
I hear these gaskets pretty good. I'm wondering if over heated prior to my purchase that's why head compression low..
I purchased car as is not running, I got going but barely wants to idle and runs severely rough.
Any help appreciated
Dean
Cruisy2650
Steve,
Dean
Cruisy2650
Yes is a vz alloytec executive
Cruisy2650
This is a recent purchase
Car was scanned by a friends work gscan scanner and he said had no faults at all .
Cruisy2650
I see car has a new water pump
On it so I suspect it may be a
Gasket ..
Cruisy2650
Picture of block
Cruisy2650
Head gasket
