VL projex, if your in the brisbane area, this guy can be a life saver.. go check it out.. 5 stars :air:
-you'll find alot of the wreckers around the area send their VL customers straight there...
As for cutting your springs...BAD idea... to be honest, if you are the kina guy that cant wait to save a few hundred for springs. It's more than likely your the kinda guy that will take her around a corner in excess of 70k's ...
In the process of "hacking" (cut is too delicate a word for this kind of butchery) your springs, you created a great amount of heat withing the coil, causing it to loose its 'temper'... Hope you enjoy rolling around corners ..
-Ak
