ls1/gen3 strocker kits????????
Discussion in 'LSx Development and Modification' started by cpbait, Jan 9, 2009.
  1. cpbait
    cpbait New Member
    vy ss commodore 5.7ltr
    Hi all,
    just wandering out of general interest what strocker kits are out there and how much they cost for an ls1/gen3 and for forged rods, pistons etc.
    which stroker kits can you get with minimal machine work to the block, i.e, like a touch up of the bores to mild machining and rough costs?
    and can you run standard sump or have to get modified sump and pickup?
    which stroker kits require a bit of machine work?
    like 5.7, 6 and 6.2 liter strocker kits through to the 427.
    just out of curiosity as my car has gudgeon pin noise and piston slap, minor at the moment, but just want to know for if it gets really bad and have to rebuild as if have to will go the go fast bits.
    i know this probably opens up a big can of questions.... like comp ratios etc, as would want to run s/c later and do cam at same time as bottom end.
    thanks, Ben.
  2. vt1538
    vt1538 455rwhp LS3
    The Dead Centre
    VY SS S2 11.284@125mph
    You can buy a built short motor for well under 10 grand from a premier engine builder.(I think it was around $7000,) Since it isnt a forum sponsor I wont name them but this is the way I would go.
  3. adamc11
    adamc11 Donating Member
    Melbourne Inner East
    2013 VE SS V Z M6
  4. cxcxcxvcvcvc
    cxcxcxvcvcvc New Member
    Disney land!
    vs calais eco
    strocker kits bahahahahah!!!
    I think C.O.M.E do stroker kits mate, give em a call:thumbsup:
    also have a look through the street commo mags and street machine mags, plenty of companies in there to!
  5. cpbait
    cpbait New Member
    cool, thanks for that yeh might give come a ring and find out, just want to know for if mine gets really bad and if not with in the next 12 months will get it anyway.
  6. BANKS
    BANKS DW I'm a Spray Painter!
    Gold Coast QLD
    VZ SSZ Ute
    starting from $3800 for a 383ci. Seems cheap. Would that be supply only or fitted?
    Imagine a 440ci with a 240+ cam WOW!!
  7. cpbait
    cpbait New Member
    yeh well i'd be looking at doing as much as i can myself being in the trade, but don't work on holdens or modified performance cars so not sure on prices and whats out there, would send for machining and what i can't do, then fit the pistons, crank, rods, cam, etc myself as i'd have the car of the road and by a cheap run about or another 4wd as a daily so could take my time and do it properly.
    yeh a 440 ci with cam would be a beast, imagine the v8 burble from that on idle then wide open throttle :D:D:D:D:D:D:D
  8. cpbait
    cpbait New Member
    id say those packages are non fitted, say another 500 or so fitted, which would still be a good price, the 427 would be good at the same price as the 383 and 408 kits, but the 408 and 427 say must use ls7 block or 4.00" bore block(408), 4.125" bore block(427), could you use the gen3 block for either of these?
    what would a 408 strocker be like or better the 383 or jump to 427?
  9. adamc11
    2013 VE SS V Z M6
    cpbait, it's spelt 'stroker' not 'strocker' :thumbsup:
    Those prices i beleive are supply only. I'm not suyre if u can use the ls1 block and bore it out, does anyone know? I would say it would cost a lot more than $500 fitted, as the whole engine would have to removed and stripped down, and then it would need a tune. It's costing me a litte under 2k labour alone (fitment and tune) for my H+C package, so no doubt the stroker kit would cost 2-3k i'd say fitted + tuned.
    Just go for the 440ci kit =)
    Edit: Okay i think you can bore the LS1 a bit but not to 4". Also found this that suggests you shouldnt do it at all...
    http://www.enginebuildermag.com/Article/1508/bringing_a_geniii_ls1_stroker_back_to_life.aspx -> QUOTE "This GM Gen III aluminum LS1 block had cast-in-place liners for a stock bore of 3.898" Taking the bore out to a 3.910" would compromise the strength of the cylinder walls and, in all probability cause them to deform under high cylinder pressure, prevalent in this boosted application. Also, the column strength of the cylinder and walls to deck may yield under applications higher than 550 flywheel horsepower."
  10. cpbait
    cpbait New Member
    oh yeh hehe thanks adamc11 stroker :D
    yeh i'd strip the engine down my self and then strip the block down myself and give them the bare block (i had that in my head when i said $500ish, alot more if they had to strip it down), then put the cam, lifters, heads (after some work to them), etc back on myself and then take it down for the run in and engine tune on there dyno then fit back into vehicle.
    yeh they charge $1650 for run in and tune for the engine only not including forced induction on the motor, thats 2 days they say including a number of oil and filter changes in that time, a couple of the bigger strocker kits on come's website they say to use the 6ltr block and ls7 for the 440ci.
  11. adamc11
    2013 VE SS V Z M6
    Just one other thing... i went for a drive in a VX SS, 242/244 cam, forged bottom end and 383 stroker. Pulled i think 330 or so rwkw. Power was bloody amazing, plant ur foot and wheels would just spin. So a similar setup would give a lot of power. He is now stroking to 408 and his engine is for sale 10k or so if anyone is interested. So, 383 is heaps of power, but if it won't cost much extra (i guess u have to buy an LS2 or LS7 block) go for a 408/427/440.
  12. cpbait
    cpbait New Member
    yeh iv always wanted a 383 stroker, if i had the money now id get the number, but will be end of year at earliest for a stroker, yeh depends on how much for an ls2/ls7 block plus any machining on top, if easier will stick with my block and 383 stroker, want to s/c later down the track so might be more than enough for that anyway. but just sussing it all out at the moment, prices, what needs to be done, replaced, best option, packages, time it would take, if easier to buy short motor or do what i can myself, etc. then make a decision and work towards it and get it done. we use an engine/machine shop that does a lot of high performance engines and i know some people who have had there engines machined and assembled there and have been very happy, so that's a big plus i guess.
  13. johnvtls1
    johnvtls1 New Member
    Melton,Victoria
    E92 BWM 335I
    mate dont bother stroking the ls1. try get an ls3 in there or at least a 6 liter and a small cam should get you 300rwkws pretty easy and not be as grumpy.i had a drive in a 383 once and it sounded nice but i dont think it could be used as a daily.
  14. cpbait
    cpbait New Member
    yeh this wouldn't be a daily although would get street driven, yeh a few people have said to get the 6ltr or ls7 blocks, if did that would the ls1 heads and that bolt up?
  15. adamc11
    2013 VE SS V Z M6
    I thought he was talking about an entire LS3 transplant.
  16. johnvtls1
    Melton,Victoria
    E92 BWM 335I
    yeh entire ls3. that with a small cam would be way better then the stroked ls1
  17. SIG-054
    SIG-054 New Member
    Willall Racing
    Y-Series Senator Signature
    agreed....
  18. cpbait
    cpbait New Member
    oh ok, yeh what are the ls3's worth as a complete motor?
  19. johnvtls1
    Melton,Victoria
    E92 BWM 335I
    i honestly think u could get it all done for 10-15 grand thats engine, cam etc, fitting + tune.
  20. cpbait
    cpbait New Member
    oh ok, nice, might think about it.
