MattK
- Nov 4, 2004
- 317
- 2
- 0
- Age
- 61
- Location
- Melbourne
- 05 VZ V6
Wow , what an ordeal !
Since I was changing spark plugs , I figured why not put on a Mace Spacer ( 12mm ) .
Changing plugs is fun like a barrel full of monkeys ( Yeah , not fun at all )
To the spacer :
My VZ has these little locator pins , and they didn't want to come out ...
And the Mace spacer has no holes for the locator pins :
So I had to drill some , Im just glad the gaskets were intact when the manifold came off so I could use them as a hole guide .
I made the guide holes a little oversize so I had some wiggle room .
Unfortunately the holes marked 1 and 2 did not really align well .. About 2-3mm to far forward .
So the 4 big bolts in the middle of the manifold went in fine , but the single bolt at each end ( small bolts ) , they didnt want to go in ..
Back to square one :
I enlarged holes 1 and 2 a fair bit and elongated them back toward the spacer ( 4 big bolts ) , this time I did a lot of test fitting .
Once I was happy with the test fitting , I assembled for the 2nd time ..
This time things went well , and it went together reasonably easy .
Just waiting for the blue stuff to cure ( 24hours )
What a day !
I sure hope the car still runs ..:rofl2:
My advice to anyone :
If you are doing it to a VZ , change your spark plugs at the same time ( Why not )
Test fit the spacer , put the bolts in , dont use the blue stuff yet .
Only if it test fits ok , then move onto doing a permanent fit !
To the spacer :
What a day !
