hello,
i have put together the info below for anyone looking to turn your standard vt in a unique beast!
1. To start we would change the wheels and lower the car - basic stuff. find a nice pair of rims that you like.
2. Now add a body kit
Centrifugal Air Pumps Australia - they have some nice basic kits for the vt , im went with the VY GTS Style Kit .
they also stock the VT Clear Tail Lights, in Silver or Black Finish.
also check out
JHP Vehicle Enhancements - Specialise in Holden Monaro and Commodore Spoilers, Body Kits, Tyre and Wheel Packages. for some bits and pieces.
im not a fan of the AERO kits but u can find out for yourself if u want one fitted.
3.Then the Exhaust System
When it comes to the exhaust system use a Berklee or lukey 2.5 inch sports exhaust system. This system will provide the ultimate flow of gases from the engine, improving performance and enhancing sound. you can have this system and fully installed in just a couple of hours.
4. EXTRACTORS / (headers - same ****!)
here is some info on them if u dont already know...
Tuned Length Extractors
They work exceptionally well in the high rev range and ideal for drag racing.
TRI-Y Design Extractors
The most common design of extractors, Tri-y extractors give you more power in the rev range that you use on the street.
As a general rule you should anticipate an increase in power, performance and fuel economy of around 10% under normal driving conditions.
5 great reasons to fit extractors to your car:
1. You'll get up to 15% better fuel economy.
2. You'll get increased performance.
3. You'll get more torque.
4. You'll get a cooler and cleaner running engine.
5. Your Auto transmission will run cooler.
We'd use a set of Pacemaker Headers which are top of the range for the VT V6 Commodore. These extractors will improve your cars performance and power and can also improve engine efficiency and fuel economy under normal driving conditions.
5.SS INDUCTION KIT
SS Induction Kits are designed to get more cool air into your engine. Cool air has more oxygen than warm air,therefore increasing combustion which results More power, better performance,better fuel economy and increased acceleration. u can get them at autobahn on the day and are easy to fit.
so your exuast set up should go like this:
Muffler (straight through) Enhances sound!
Hi-flow cat converter Better flow than standard.
Extractors Improves power & efficiency!
2.5 inch system Delivers better performance!
SS Induction Kit Get faster acceleration!
thats the basics for the vt, you can then really tweak it with changen the diff, pushrods, etc etc.
hope this helps!
enjoy.......
:yeah:
