no injector pulse but no PCM error codes
jeepster
WA
VSII Ute
My V6 was running smoothly yesterday, then 20 minutes later would not start. It cranks over, and has a spark. Eventually find no injector pulse.
The fuel pump is working. The imobiliser red LED has gone out. I checked fuses, swapped relays - no change.
So check for error codes, only get 12. Any suggestions (apart from PCM dying)? I presume if crank angle sensor were defective, it should flag an error code.
One thing, when trying to start, I hear a faint chirping sound in the engine bay. I never noticed this before.
aussie4life
Keep It Simple Stupid
South Australia
2010 VE International 3.0L
CAS doesnt always show an error code. theres no after market imobiliser?
woteva
NEED 4 SPEED
Adelaide S.A.
If CAS was faulty, there would also be no spark.
Just had a quick look at the circuit and there is an EFI Relay and Fuse to check first.
BlackVXGTS
Melbourne, SE
Check EFI earth wire behind drivers side kick panel.
JJ's VR
VRHLDN
VR 3.8lt Supercharged 163.8kW & VS sII HSV Senator
I have a vr v6 too, and exactly the same thing happened to me. All I had to do to rectify problem was turn ignition on, leave it on for 2 minutes then start it (without turning ignition off then back on) My problem was memcal related.... Good luck.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
i would go for a cas or a dfi under the coils first they can go and you still get spark but the ecu doesnt get a signal
