omega my10 steering wheel loose
Discussion in 'VE Holden Commodore (2006 - 2013)' started by h8tensv6, Mar 17, 2017.
  1. h8tensv6
    h8tensv6 Member
    Newcastle NSW
    2009 MY10 SV6 2002 VX S2
    My wife has been telling me for weeks now her steering wheel seems loose. I checked it out today and if you hold the wheel with hands at 9 and 3 oclock position you can move the wheel left and right about 3 or 4mm. If I hold the wheel at the top and bottom I can move it up and down the same amount. Does this indicate a loose steering wheel or worn bushes in the steering column and is this something I can fix myself or does it need to go to holden.
  2. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    possible bearing on the steering column, does the steering wheel move in and out, hold at 9-3 and push pull, the wheel is splined and has one larger spline to align correctly if you take it off, connection of the intermediate shaft to rack, column support bolts top and bottom
  3. h8tensv6
    h8tensv6 Member
    Newcastle NSW
    The wheel wont move in or out only side to side and up and down. I might see if I can find what it is. Is there a write up on removing the air bag. If I do that it will rule out a loose nut holding the wheel (apart from me).
  4. h8tensv6
    h8tensv6 Member
    Newcastle NSW
    Sorry I found the write up on removing the wheel. Will see how it goes.
    MYVESSV8 likes this.
  5. Benboy
    Benboy Well-Known Member
    Hill River, SA
    2007 SVZ Wagon
    With a defective steering your vehicle may potentially be a threat to other motorists and pedestrians. Please get it checked by an accredited mechanic before something goes really wrong. In the meantime, please don't drive it on a road (OK if you want to drive on private property or go paddock bashing etc)
  6. dans_vz
    dans_vz Member
    Albury/Wodonga
    2011 VE II CalaisV SWagon & 92 VP II Calais V8 5sp
    Seriously WTF Benboy? Do you even think before you post? Who paddock bashes a VE that their wife drives? Do you think he doesn't realise the wheel may be a 'threat' hence why hes asking for help on here? (Thats the job of this forum, to help others funny enough)
    Why do you feel the need for posting stupid warnings/disclaimers on everyone's posts? This is whats wrong with Australia these days, this sort of garbage.
    /End rant.
    Tonner Matt and lmoengnr like this.
  7. h8tensv6
    h8tensv6 Member
    Newcastle NSW
    Thanks for worrying Benboy but my wife isn't driving the car as we have a runaround car she can use and I definitely wont be bush bashing it because she will skull bash me. I don't have time to look at it this weekend so I have booked it in to Holden so they can diagnose it for me. As soon as I saw how bad it was I took the keys off her so she can not put her life or anyone else's life in danger. Dans_vz I thought it was funny when I read benboys post. I almost spat my coffee all over the monitor. I had a good laugh. No harm done.
    Tonner Matt, dans_vz and MYVESSV8 like this.
  8. h8tensv6
    h8tensv6 Member
    Newcastle NSW
    Update time. Car went to holden to check out the issue. They found the bolt holding the wheel on had come loose. They told me it could have been 2 possible scenarios. 1 it was never done up tight enough when the car was made and worked its way loose, (highly unlikely) or 2 the previous owner or mechanic has had the wheel off for some reason and didn't do up the bolt tight enough. All good now and wife is safe and cost me $120 to get done. If the wife is happy everyone is happy.
    MYVESSV8, greenacc and VS_Pete like this.
  9. VS_Pete
    Thanks for the update.
    Glad mum is happy
  10. Tonner Matt
    Tonner Matt Active Member
    Darwin
    VZ 1 Tonner LS1 M6
    Well said mate, posting stupid warnings & disclaimers seems to be his thing.
    I'm quite surprised he didn't tell the O.P the vehicle is unroadworthy and is currently not complying to ADR's.
    dans_vz likes this.
  11. Tonner Matt
    Darwin
    VZ 1 Tonner LS1 M6
    Good to hear you got it sorted mate and wasn't a major drama :)
    And the wife is driving a safe car again (LOL)
    VS_Pete likes this.
  12. dans_vz
    dans_vz Member
    Albury/Wodonga
    Haha seriously it gets tiresome on every second post, im suprised that not many others make comments on it.
