sorry about the dealy, but time to settle this once and for all
there is a set way of checking the cas, you need to disconect the pin's from the cas, and measure the resistance. if it goes over a certain value it's buggered. a cas is a hall effect swtich, what does is pic's up when piston no one, is comming around. it then tells the ecu, and the rest is history.
if you dont have injector pulse,and dont have spark, and it' strying to start, you can safely assume it's the cas.
i not to long ago replaced a member of this site's cas for her. it gave the following symptons.
no spark
no injector pulse
tested the injectors, they were fine (that was just for my own sake)
t ested the cas using a multi meter, (set on the ohm's scale only, a auto ranging meter would be a better option, saves you converting k ohms or m ohms back to ohms.
i replaced the cas and it started and died, (it died from a different problem, fuel problem.)
you cant check the cas with a cro. cas dont put out a signwave, it's a magnet, it's called a hall affect switch. all it does is picks up changes in magnetic relaionship to the harmonic ballancer.
you can test if the dfi and ecu are talking to each other, on the series one vn and 2, look for the very last slotted pin spot on the dfi connector. it' scalled pin "j" you stick your multi meter in there and put it on a good earth. (independent from the dfi moduel, like the alternator body, you should get the battery voltage, if you have it, the ecu is fine.
like jules said, backprobing is the easieest thing out there to do, i would have to say, i dont know why it's called back probing, it is more a continuity test to make srue there is no cable dammage or anything else amiss there.
should you require any futher info, email
[email protected] and ill be more than happy to make up the resistance value's for you for the vn series 1 and 2 commodore cas.
but my money is on the cas
cheers
garth
