Preferred fuel for 6.2 L LS3
Discussion in 'VF Holden Commodore (2013 - ?)' started by flackjax, May 17, 2016.
  1. monstar
    monstar Active Member
    Uranus
    VVT Redline, Motherfucker
    So, that's a no. Thought so, thanks for your technical consultation on this matter nevertheless!
    07GTS likes this.
  2. NN334
    NN334 New Member
    Lake Macquarie
    VF Calais V 6.0lt
    I have seen it but not on my vehicles, as I won't run a cheaper grade fuel with an elevated Octane.
  3. Paulie81
    Paulie81 Member
    NSW
    NA
    I use Caltex or BP 95 and never use 91 or E10
  4. monstar
    Uranus
    Ah right, crappy regular (low level) refined sulphurous gummy gasoline sludge propped up and made good with a shot of ethanol. Makes sense it's the shitty petrol not the ethanol that causes premature failure. Take United e10 as a clean, performance fuel example that competes favourably in our car by meeting the engine octane requirement, value for money, and brings additional benefits of ethanol.
    Even higher ethanol fraction fuel helps to prolong component life in our car generally, decoking the engine and promoting thermal efficiency under typical to high load. Perhaps because our Aussie cars are made for it but our Zeta injectors and pumps have clearly proven to last longer than with petrol in mass sample long-term testing, possibly due to reduced operating temps vs the spectre of oxidation and scoring from hydrous flow and storage.
    The one notable caveat being aftermarket high carbon (mild steel) exhaust systems which oxidise prematurely and spectacularly. However in this niche V8 performance sector two years between switching catbacks is almost acceptable, else shell out for stainless.
    07GTS and 426Cuda like this.
  5. Redline457
    Redline457 New Member
    StKilda
    VF1 6.0 SSVR A6 W457, VF2 6.2 SSVR M6
    BP Ultimate 98 for me also or Mobil 98 if I can't get BP.
